Forces to crack a pouch after a fall
The discussion centers on the forces exerted on a balloon filled with one liter of water when it falls from a height of one meter. The calculated gravitational potential energy at impact is 9.81 Joules, but the balloon experiences greater risk of cracking upon impact compared to static pressure tests where it withstands up to 2000 Newtons without damage. Dynamic effects, such as strain rate and stress concentrations, significantly influence the balloon's integrity during a fall. The conversation also touches on the hydraulic pressure exerted by the water on the balloon walls and how the balloon's non-rigid structure complicates the impact force calculations. Understanding these factors is essential for assessing the balloon's failure threshold upon impact.
rah
Hi
I have a question I need help with.
Im trying to find out how much forces that a pouch (balloon) creates on the inside walls when it hits the floor after a fall.
A pouch (balloon) with one litre of water falls from 1 meter down to the floor.
How much force must the "walls" stand before they crack?
I have tryed to put a known force on top of the pouch and it stands quite a lot.
But when I drop it on the floor it cracks "a lot easier".
R
1 l of water = 1 kg and 1 m, mgh = 1 kg * 9.81 m/s2 * 1 m = 9.81 J.
Does the static force on top of the balloon apply a for equivalent to 9.8 J?
There are dynamic effects and stress concentrations that play a role. When the balloon drops there is a strain rate effect as well as a non-uniformity in the stress field that can cause the balloon material to tear. Some of the stress non-uniformity will arise from friction between the balloon and impact surface, as well as non-uniformity in the wall of the balloon.
Thank you for your quick reply.
If I understood you right the force that the balloon hits the floor with is 9,8J or Newton.
The force I use when I pressure test the pouch is 2000N and the pouch doesent have any sign of cracking.
Is it possible to calculate the pressure the water creates on the walls. Is that hydraulic pressure?
R
R
When the balloon drops, the gavitational potential energy converts to kinetic energy until the balloon hits the floor (9.8 J). When the balloon hits the floor, the force is determined by the impulse relationship, but it's complicated since the balloon is not rigid. The water deforms as it collapses and the balloon is pushed out sideways (radially) - and there is probably an acoustic/shock wave reverberating through the water.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
