Understanding Drag Force: Standard Formula vs. Alternative Formula Explained
The standard drag force formula, FD = 1/2 CD * ApV^2, incorporates the drag coefficient, cross-sectional area, fluid density, and velocity. An alternative formula, FD = 1/4 AV^2, provides an approximate relationship under specific conditions. This approximation assumes a constant drag coefficient and fluid density, which may not hold true in all scenarios. The simplified equation FD ∝ A⋅V^2 is applicable only when area and velocity change while maintaining a consistent profile in a uniform fluid. Understanding the limitations of these formulas is crucial for accurate drag force calculations.
jason bourne
I know that standard formula is, FD = 1/2 CD *ApV^2
FD = Drag Force. SI: N
CD = Drag Coefficient. SI: Dimensionless (Typical Values)
A = Coss-sectional Area perpendicular to the flow. SI: m2
r = Density of the medium. SI: kg/m3
v = Velocity of the body relative to the medium. SI: m/s
But our prof also said there's another formula for drag force,
FD = 1/4 AV^2
(Its is not supposed to be equal but approximately)
So the question is when is the equation above false, what's the error in the equation that makes it approximate.
Such a simple equation assumes that CD⋅ρ = 0.5
Where ∝ means proportional to; FD ∝ ¼⋅A⋅V2
can be further simplified to; FD ∝ A⋅V2
That can only be applied where changes to area or velocity occur, while maintaining a constant profile in a constant density fluid.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
