Stark Effect Experiment: Observing Splittings with 600 Grooves/mm Spectrometer
amalmirando
Hi,
Is it possible to observe stark splittings with a 600 grooves/mm attached to a spectrometer.I carried out the experiment by placing the hydrogen tube in between the spark gap of the rhumkorff coil but was unable to see splittings.Wonder whether it was the lack of resolving power of the instrument or an error in the apparatus..
can a michelson interferometer be used for the observation?
i tried to do the expt some time ago but it too didn't workout...lack of proper documentation is a big issue i guess.how about using two parallel plates to produce a uniform electric field?
i guess you are correct in stating the lack of documentation.i tried with two parallel plates.but it too didn't work out...
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
