Is the characteristic function constant everywhere if it is constant at 0?
The discussion centers on the properties of characteristic functions (ChF) in probability theory, specifically whether a ChF that is constant in a neighborhood of zero must be constant everywhere. It is noted that while the characteristic function at zero equals one, there is no general proof that a constant ChF implies constancy across the entire domain. The conversation highlights the need for clarity regarding the topological space in question, as definitions may vary in different contexts. A reference to Feller's work suggests that a ChF with constant absolute value is periodic and represents distributions concentrated on a lattice. The inquiry emphasizes the complexity of characteristic functions and the need for further exploration of their properties.
wayneckm
Hi there,
Recently I have come across a proof with application of characteristic function.
After some steps in the proof, it concluded that there is a neighborhood of 0 such that the characteristic function is constant at 1, then it said the characteristic function is constant at 1 everywhere over the domain.
I suspect that "If there exists a neighborhood of 0 such that the characteristic function is constant, it is constant everywhere." Is this correct?
I have tried to search from the web regarding this but found nothing. Would anyone suggest me some good reference on characteristic function as well.
Thanks.
Wayne
Thanks.Wayne
It's true that
\varphi (0)=\int_{-\infty}^\infty f_{X}(x)dx=1.
However, I'm not aware that the ChF is constant anywhere for any PDF. Can you provide the source? Perhaps you are you talking about the (Dirac)delta distribution?
EDIT: The characteristic function is apparently defined differently in a non-probabilistic context. See the first paragraph of the following:
http://mathworld.wolfram.com/CharacteristicFunction.html
The question doesn't make any sense, since you don't specify what topological space you are working in.
wayneckm said:
... it concluded that there is a neighborhood of 0 such that the characteristic function is constant at 1, then it said the characteristic function is constant at 1 everywhere over the domain.
An interesting generalization of the result is proved in Feller (vol 2 p 475), namely that any c.f. with constant absolute value is of the form \psi_X(t) = e^{ibt}, i.e. |\psi|=1 and the distribution of X is concentrated at b; moreover any c.f. that achieves absolute value 1 away from t=0 is periodic and represents a distribution concentrated on a lattice.
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
