Solving for x: Uncovering the Golden Ratio
The discussion centers on solving the equation tan x = cos x, revealing that the solutions involve the golden ratio. Participants clarify that the real solutions can be expressed as x = ArcSin((Sqrt(5)-1)/2) + 2*k*Pi and x = Pi - ArcSin((Sqrt(5)-1)/2) + 2*k*Pi, with k being any integer. They note that sin^{-1}(\phi) and sin^{-1}[-(1+\sqrt{5})/2] are not real solutions. The analysis confirms that there are valid solutions within the specified domain, emphasizing the relationship between the functions involved. Ultimately, the discussion highlights the mathematical intricacies of the problem and the significance of the golden ratio in the solutions.
Helios
If tan x = cos x, then what is x ? The answer includes the golden ratio !
Mathematics news on Phys.org
You obviously know the answer, so why are you asking?
So let s = sin x, c = cos x; then s/c = c, so s = c2 = 1 - s2. Solve for s, then take arcsin. Easy.
To be exact...
Answer = sin^{-1}\left(\phi\right)
You forgot the other solution: \sin^{-1}\bigl[-\tfrac12(1+\sqrt5)\bigr]. (Not a real solution, though.)
I tend to use the real numbers.
Complex numbers are not often the solutions to questions found in the general math section.
EDIT: I just realized that sin^{-1}(\phi) isn't real either... wow, so there are actually no real solutions.
Tan(x) = Cos(x)
Real solution are :
and
k = any négative, nul or positive integer.
JJacquelin said:
k = any negative, null or positive integer.
So, in other words, any integer?
Yes, indeed ! :wink:
So cos(x) doesn't cross tan(x)?
Mistake number two...
The real solution is in fact:
sin^{-1}\left(\frac{-1}{\phi}\right)
I think, assuming that
\frac{-1}{\phi} = \frac{1-\sqrt{5}}{2}
Which I seem to remember a similar property about phi...
note that
tan( x ) = cos( x ) = 1 / sqr( phi )
so the solution can be made in terms of arctan or arccos.
Since tan(x) increases monotonically from 0 to infinity in the domain (0, pi/1) and
cos (x) decreases from 1 to 0 in the same domain, there should be a solution x between 0 and pi/2 and 0< sin(x) < 1. There's a solution in the second quadrant as well. cos(x) and tan(x) have different signs in the 3rd and fourth quadrant, so a solution where sin(x) < 0 is not possible
Once you get all the signs right in the quadratic formula, you'll get
sin(x) = \frac {1} {\phi} = \phi - 1
from one of the solutions. The other solution has sin(x) >1 so that isn't a valid solution.
