Understanding Binary Signals and the Mystery of Bytes
  • Thread starter Thread starter luckis11
    bytes
Binary signals at gates can only represent individual bits, either 0 or 1, and not complete bytes, which are typically formed by groups of 8 bits. The output of gates is limited to either all zeros or all ones, raising questions about the existence of bytes in this context. Gates can operate in parallel to manage multiple bits, but many applications do not involve byte formation. An example is a frequency counter, which measures the rate of incoming pulses using precise timing. Ultimately, while gates can contribute to byte formation, they primarily function at the bit level in various applications.
luckis11
Each signal that arrives at a gate cannot be a byte, or if it is, can only be 11111111 or 00000000. Also the outcome of each gate is 000...000 or 111...111. So where are the bytes?
(The question might be wrong but if I knew the right question I guess I would had known the answer too).
8 gates in parallel could be used to hold and transfer bytes.
Gates usually only handle one bit at a time, as you suggest.
There may not actually be any bytes.
One good example is a frequency counter.
You have a stream of pulses coming into one input of a gate.
Another input has a very precise pulse applied to it. This pulse might last for exactly one second.
So exactly one second's worth of pulses is allowed through to a counter.
So, you get a reading of how many pulses there are per second. That is the frequency of the incoming signal, which is the function of the instrument.
Gates are used in many different ways and quite a lot of them don't involve forming bytes.
When they are, they can be used in sets of 8 or 16 to produce a parallel output of one byte.
Or, there can be a clock which produces the byte as a sequence of 1s and 0s one after the other.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
