Let X be uniformly distributed on (0,1)
  • Thread starter Thread starter TomJerry
    Distributed
The discussion focuses on proving that the transformation Y = -λ⁻¹ ln(1-X), where X is uniformly distributed on (0,1), results in Y having an exponential distribution with parameter λ > 0. The moment generating function (MGF) approach is highlighted, demonstrating that if two distributions have the same MGF, they are of the same type. The MGF of Y is derived through integration, leading to a form that matches the MGF of the exponential distribution. Additionally, the density function transformation method is mentioned as an alternative proof. Overall, the discussion effectively establishes the relationship between the uniform and exponential distributions through mathematical transformations.
TomJerry
Question:
Let X be uniformly distributed on (0,1). Show that Y=- \lambda-1 1n(1-X) has an exponential distribution with parameter \lambda>0
Do you know what generating functions are?
let
<br /> F_Y(y) = P(Y \le y)<br />
and use the definition of Y to rewrite the inequality in terms of X.
Nope !
Here is how you can do this with a moment generating function.
Basically you can prove that a distribution is a particular one if both moment generating functions are of the same type.
So for example you've given Y = - 1/(lambda) ln(1 - X).
We are given that X is uniform on (0,1) so basically standard uniform.
The PDF of X is simply 1 with the domain (0,1).
The MGF of Y is given by M(t) = E[e^(Yt)] = Integral [0,1] 1 x e^(-{1/lambda} x ln{1-x} x t) dx = Integral [0,1] (1-x)^(-t/{lambda})
Using a substitution we get u = 1 - x, du = -dx which gives us the integral
M(t) = Integral [0,1] u^(-t/{lambda}) du.
This gives us M(t) = 1/{-t/lambda + 1} which corresponds to the MGF of the exponential distribution.
You can also use the standard formula for computing the density of a strictly increasing function. If X has density f_X(x) and Y=g(X) is strictly increasing, then Y has density f_Y(y)=f_X(g^-1(y))*dg^-1(y)/dy
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
