Pls can someone help me to solve this question, am practicing for my exams.
  • Thread starter Thread starter smokee
    Exams
The discussion revolves around calculating the number of moles of photons needed to raise the temperature of a 500g sample of water by 2°C using a CO2 laser. The specific heat capacity of water is 4.184 J/g°C, leading to a total energy requirement of 4184 J for the temperature increase. Participants clarify the energy of a photon at a wavelength of 1.06 × 10^4 nm and confirm that the calculations do not require converting grams to kilograms, as the heat capacity is given per gram. The importance of correctly interpreting the wavelength and energy calculations is emphasized. Overall, the thread provides a step-by-step approach to solving the problem.
smokee
The specific heat capacity of water is 4.184 J/g°C. A 500g sample of water is exposed
to the light emitted by a CO2 laser. The wavelength of the laser light is 1.06 × 104 nm.
Assuming that all of the light energy is converted into heat, calculate the number
moles of photons required to raise the temperature of the water by 2°C.
sorry folks, can anyone give me a little insight about BONDING and ANTI-BONDING ORDER in MOLECULAR ORBITAL.
cheers alot. SmokeE
I have no idea about "bonding" and "anti-bonding" but the first part of your question is just a matter of arithmetic. You are asked about raising the temperature of the water 2°C so that will require (4.184 J/g°C)(2°C)= 8.368 J/g. You have 500 g of water so that will require (8.368 J/g)(500 g)= 4184 J.
Now, how much energy does a photon of light at 1.05 x 104 nm (was that 10-4? It couldn't be just 105*104 nm or 105 x 104 nm and still be "light".)
have? Divide 4184 J by that to see how many photons are required.
@hallsofivy - thanks for the reply its 105*10^4 nm =105*10^-5 m because nm = 10^-9
thanks a lot it helped
sorry bro, will i not have to convert the 500g to Kg?
cheers
Heat capacity is given per g, not per kg.
@ hallisofivy
Thanks for helping bro :L
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
