What Would Happen if a Supercap with 318 Wh-kg Energy Explodes?
  • Thread starter Thread starter Stanley514
Recent discussions highlight the potential of supercapacitors with energy densities reaching 318 Wh/kg, raising concerns about their safety in applications like hybrid vehicles. The risk of explosion from such supercaps, particularly in crash scenarios, is debated, with distinctions made between overheating and electric field-related failures. While traditional explosives like TNT are preferred for their rapid explosiveness, supercaps may pose unique risks if damaged, potentially leading to thermal expansion and bursts. Comparisons to the energy density of gasoline show supercaps still have a long way to go to match conventional fuels. Overall, while supercapacitors offer promising energy storage solutions, their safety and practical applications remain critical considerations.
Stanley514
There is a claims that some scientists have developed supercaps with specific energy as high as
318 Wh-kg.Some ot them are using pseudocapacitance principle http://www.springerlink.com/content/w542251jg6034207/"
Im really wondering what would be the power of explosion of such type supercap if it will be installed, let's say, in a hybrid auto?I remember some wrighter wrote that he was terribly scarried by exposion of capacitor with millifarad capacitance in an old-type TV.
So what will happen if supercap with million times greater energy will explode?And also why military is still using traditional explosives?Would not 318 W-kg supercaps be a new word?
Also what about terrorists who will be able to make or purchase such a supercaps?
I whish to know what type of supercap is less dangerous: these based on pseudocapacitance,double electrolitic or graphene based type?
Stanley514 said:
...supercaps with specific energy as high as
318 Wh-kg... what would be the power of explosion of such type supercap if it will be installed, let's say, in a hybrid auto?...
318 watt-hr/kg ~1.1 106 J/kg.
Energy density of ordinary gasoline is roughly 3 107 J/kg.
So they have a way to go to even match the energy density of good old fashion gasoline.
The exploding capacitor you mentioned most likely had burst from excess fluid pressure caused by overheating--not from electric field energy.
That`s exactly true,but explosiveness of any explosive material is defined by power density rather than energy density.This is why TNT is used instead of gasoline or natural gas.Because it could explode much faster than a gas.
What is difference between overheating and electric field explosion?For example if hybrid auto on supercaps will get into a crash and supercap will be physically distructed what power of explosion could be?
Those supercaps which use effect of pseudocapacitance are less dangerous or not?
Stanley514 said:
...What is difference between overheating and electric field explosion?
For fun we can calculate some pressures. For the capacitor in the TV, assume 1 millifard at 300Volts. Guess a can size of 2" diameter by 3" long. then the pressure calculates to
(1/2).001 F (300 Volt)2 /(pi (1 in)2 3in)~3 atm.
For the super Cap mentioned assuming a mass density of 2 gm/cc we get
(2 gm/cc)*318 watt hr/kg~2.2 104 atm.
Which is certainly impressive, but these are all negative pressures. The force between capacitor plate is attractive. How do you get an explosion out of that?
Regarding the exploding TV capacitor: Those capacitors were sealed into a metal can filled with liquid electrolyte. A short circuit could heat the contents and cause it to burst. But that is not what I would call an electric field explosion. It's like leaving an aerosol can in a car with the windows rolled up on a very hot day.
You answered yourself to you question.Also I suggest that when supercap is physically distructed it will probably short circuited and explode because short circuit will cause a thermal expansion of very high power and hence explosion.I think that large supercups may never by used in hybrid vehicles unless they will not provide huge cevlar casing for protection.But they still may be used in wind or solar power apps...
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
