Question about filtering out the blue wavelength from lights
  • Thread starter Thread starter vande060
    Lights Wavelength
The discussion revolves around finding a solution to filter out blue wavelengths from a light source for a research project. Participants suggest using photographic filters and discuss the differences between notch filters, which absorb specific wavelengths, and low pass filters, which transmit others. A method to test the effectiveness of the filter involves using a blue filter to check for the absence of blue light. The conversation highlights the availability of optical filters from various manufacturers and the potential use of inexpensive Wratten filters with known optical properties. Ultimately, the participant plans to recommend these filters to their professor based on the gathered information.
vande060
I volunteered to help out with a research project, and we need a solution for a way to filter out light of the blue wavelength from a light source. THe blue wavelength is the only wavelength we want to remove. I was wondering if anyone here had any suggestions? Someone from the project suggested a photographic filter, and this is a good idea, but if we bought a color filter from a photography shop how could we know that it was working? I thought we might be able to file one and put the filings in a cuvette in solution and place that in a photospectrometer to see if the peak absorbance is 440-490. Or maybe there is an optics reference book with the absorbance of materials?
Science news on Phys.org
I'm confused- are you looking for a notch filter (absorbs a waveband) or a pass filter (transmits a waveband)? Either way, why do you have to grind one up to measure the transmittance?
There are many companies that make filters- Omega, Hoya, Chroma, Semrock, Tiffen,... yours is probably a stock item, or close to one.
it would seem he's looking for a low pass filter ... so from a white light source, he wants the blue end filtered out leaving all the rest to pass through.
@vande060 ... how would you know its working? easy, put a blue filter in front of the light coming out if the other filter it should be dark, ie. no blue light present to come through the blue filter
Dave
Andy: it sounds like they're looking for a notch filter to remove blue. I'm not sure if a low pass would be sufficient (it depends on whether they want to keep the UV or not).
Optical filter sites are very helpful. I just didnt really know the title of what I was looking for. Thanks for the info. I think I am looking for a notch filter. I don't want the blue light to be transmitted from the source, and I'm hoping to find a filter that will absorb it and reduce transmittance. They are pretty expensive though, maybe the photography shop has something to offer.
I actually found a list of optical properties for wratten filters(kodak company) in the crc. They are very cheap, and I have some nice quantitative data to go with them. Just in case anyone was interested, I think I'm going to suggest these to the professor.
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
