Surface Tension: Is Intermolecular Force the Answer?
Surface tension is primarily caused by the imbalance of intermolecular forces at the surface of a liquid compared to its bulk. In water, hydrogen bonds create a stabilizing network for molecules in the bulk, while surface molecules experience fewer stabilizing interactions, leading them to retract inward. This tendency for surface molecules to minimize their exposure to air results in a spherical shape, as spheres have the smallest surface area-to-volume ratio. Liquids with stronger self-interactions, like water, exhibit higher surface tension than those with weaker interactions, such as diethyl ether. Ultimately, the strength of intermolecular forces directly influences the degree of surface tension in various liquids.
calculus_guy4
On my test it asked what causes surface tension. The teacher says the correct answer is that "the intermolecular forces are stronger at the surface of a liquid than in the bulk of the liquid." Is that correct?
Not really? I don't want to say your teacher is wrong, but that description does not conform with my understanding of surface tension.
Think about water as an example. In liquid water, you have a network of hydrogen bonds that are very stabilizing and favorable. A water molecule in the middle of a drop is surrounded by other water molecules, and is fully involved in these stabilizing interactions. However, at the surface, things change. The part of the water molecule at the interface with air is no longer stabilized by these favorable interactions, and so it wants to retract back into the liquid, where it can engage in more hydrogen bonding. Expand that to all molecules on the surface; they all are trying to contract inward, and so the liquid takes on a spherical shape to minimize the number of molecules that are in contact with the surface (spheres have smallest surface area: volume ratio). The more a liquid prefers self-interactions to interactions with a surrounding substance (air, oil, etc), the higher the surface tension. So look at water and diethyl ether. The former has a much higher surface tension with air. Why? Because the ether solution lacks the capacity to form strong hydrogen bonds, the molecules at the surface have less 'incentive' (so to speak) to get back into the middle of the solution.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
