The Relativistic Hookean Spring: A Lorentz-Covariant Force
atyy
What is the simplest Lorentz covariant force - the relativistic version of an ideal Hookean spring in Newtonian mechanics?
"Simplest" as an easy to do an ideal calculation with.
I would say that a Lagrangian density of -rho is the simplest relativistic equivalent to a spring - but I also suspect that's not quite what you're after, it's not formulated as a particle-particle force, and to turn it into one, you'd have to define the motion of the spring which starts to get non-simple.
http:http://www.gregegan.net/SCIENCE/Rindler/SimpleElasticity.html talks about it a bit, though he doesn't use Lagrangians.
I think https://www.physicsforums.com/showpost.php?p=1365762&postcount=157 was what I finally came up with for the Lagrangian density of a hoop, not that you're doing hoops. It should also work for a wire. You'll see some added terms there, related to the terms due to the motion of the wire, and the energy involved in stretching it.
Getting the volume element right was a painful process. And the stretch-factor computation isn't trivial, either - as you'll see if you have the patience to read the very very long thread. And the last caveat is that the speed of sound in the wire goes up when you stretch it, and when that speed gets to be faster than 'c' bad things happen, bad things including singular Lagrangians.
On the other hand,I suspect it's not quite what your'e after, so you might not want to bother.
@pervect, thanks too!
I guess what I was after is trying to think about this thread https://www.physicsforums.com/showthread.php?t=508190&page=2 .
In the cleanest version of the story, we set up the balls to have equal and opposite velocities in the train frame, and then just use velocity addition. In a sense, the balls then have always been moving that way, and the asymmetry judged from the platform has always been present.
In hprog's set-up, he says the man on the train pushes with "equal force". My intuition is that the final velocity of the balls is determined by force times time. The balls will leave the force field at the same distance (in both frames) from the center, but at the same time in the train frame, and not in the platform frame. So I wanted to know a "simple force" to enter into the calculation.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
