Ordinary and covaraint derivative
  • Thread starter Thread starter world line
    Derivative
world line
Hello
what is the meaning of covaraint derivative ?
where the ordinary derivative of a function whit respect to a variable is zero, it means that function doesn't depend on that variable.but what about covaraint derivative ?
for example the metric tensor may depends on coordinate but its covaraint derivative is zero.
The classical (directional) derivative is dependent on your choice of coordinates. The covariant derivative is not; is it covariant in the sense that it is defined in such a way as to be independent of its description in a particular coordinate system. That is why it is written as a directional derivative plus a term that compensates for any changes in coordinates, expressed through the Christoffel Symbols. It is basically a generalization of the classical derivative into Riemann geometry.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
