Can Kinetic Energy be Determined without Finding Velocity?
Kinetic energy (Ek) cannot be accurately determined without finding velocity, as the manipulation of the equation Ek = 0.5mv^2 leads to incorrect conclusions. The discussion highlights that using average values and improper definitions of acceleration results in flawed calculations. Work (W) should be defined as W = FΔx and requires a change in distance, not just a mathematical rearrangement. The assertion that kinetic energy can be found as half of the work done is incorrect; work done on an object must equal its kinetic energy. Proper understanding of the relationships between force, work, and energy is essential for accurate physics calculations.
Jose094
Ok, so I had to find a way to find Kinetic Energy without finding the velocity, so I decided to move the equation, Ek=.5mv^2. Now then Ek.5m(x/t)^2 where x is distance and t is time. Work on the other hand is W=Fx, and F=ma, W=ma*x and a=(x/t^2), hence, W=m* (xx/t^2) or W=m*(x^2/t^2) or W=m*(x/t)^2. which is also the second part of the Ek equation, therefore, Kinetic Energy can be found by finding half of the work, could this work, is this actually possible or did I do something completely wrong?
The problem is that you're using equations for average values, you need to be doing the actual calculus:
W=\int F \hspace{0.05in} dx = \int ma \hspace{0.05in} dx
If acceleration (and mass) is constant...
W = ma \int dx = ma*x
So this part is like you said. But, for constant acceleration x does not equal (x/t^2) (because the velocity is not necessarily zero)
x = v_0 t + \frac{1}{2} a t^2 \rightarrow a = \frac{2}{t^2}(x-v_0 t)
Thus, W =m \frac{2x}{t^2}(x-v_0 t)
Your expression ends up being correct, if both the acceleration is constant, and the velocity is zero over the entire path (i.e. both the acceleration and velocity are zero), and thus the work and kinetic energy are both zero.
Yes, this is not a valid method of manipulating equations. Things like Work are defined like W = F \Delta x, a change in a distance, given by x - x_0. This is the same for everything else. Only when the initial position/velocity/whatever is 0 is this even remotely capable of working and it would only work numerically, it's not proper algebraic manipulation.
The REAL problem in what you have is your definition for acceleration. In a slightly more proper sense (yet still wrong), the acceleration, as you wrote it, would be a = {{\Delta x}\over{\Delta t^2}}. However, this is also a = {{v_{average}}\over{\Delta t}} which, and you can easily verify, is not at all correct.
Plus, think about this for a second. If a particle were to accelerate from rest to a certain velocity, the work done on the object must EQUAL the kinetic energy, not be 1/2 of work.
Thank you both, I knew I was wrong, just really wanted an opinion from others since it really seemed like I was just manipulating random equations. Thanks!
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
