Why is NGSPICE giving me wrong results for my inverter simulation?
  • Thread starter Thread starter Kholdstare
The discussion centers on an issue with NGSPICE simulation results for a basic inverter using the IBM 65nm model, where a delay of 4ns is observed instead of the expected 8-15 ps. The user suspects an error in NGSPICE version 24 and shares their circuit configuration. Suggestions include adjusting transistor dimensions from default values to more realistic ones. A helpful resource is mentioned, allowing users to run SPICE simulations online, which may assist in troubleshooting similar issues. The conversation highlights the importance of accurate parameters in simulation for reliable results.
Kholdstare
I was trying to simulate basic inverter with mosis IBM 65nm model file (lvl 54 BSIM 4.3.0). And I am getting a delay of 4ns whereas I should get 8-15 ps. I don't understand why it is giving me wrong results. I suspect ngspice (ver 24) is doing it wrong.
Thnx
subckt.txt
* Inverter
.SUBCKT INV IN OUT
M1 OUT IN GND GND nmos
M2 OUT IN VDD VDD pmos
.ENDS
test.txt
* Inverter
.INCLUDE D:\ngspice\bin\0_Models_mosis_ibm_65nm_l54.ftr
.INCLUDE D:\ngspice\bin\subckt.txt
.GLOBAL GND VDD
XINV IN OUT INV
VDD VDD GND 1V
VIN IN GND PWL(0 0 10ns 0 10.1ns 1 30ns 1 30.1ns 0)
.TRAN 0.01ns 50ns
.END
.CONTROL
run
plot in out
.ENDC
Bump. I even see high capacitive Miller coupling effect.
Thnx,
your current circuit has transistors with L=5um and W=5um (default values). You may consider changing these to real values.
Holger
Yeah, found the bug at last.
For simple netlists like this, http://www.ngspice.com can be very helpful. This site allows you to run SPICE simulations from a web browser. There is also an example circuit similar to yours that may have helped to identify the problem that you were having.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
