How Does an Electric Current Supply More Energy to Higher Wattage Appliances?
  • Thread starter Thread starter esmeralda4
    Watt
Electric current supplies more energy to higher wattage appliances due to differences in resistance, which affects how much current is drawn. Higher wattage bulbs, like a 100W bulb, have lower resistance compared to lower wattage bulbs, allowing them to draw more current and produce more light. The temperature of the filament also plays a crucial role; as the filament gets hotter, it emits more light. Additionally, the design of the filament in higher wattage bulbs concentrates heat more effectively, resulting in a brighter glow. Understanding the relationship between resistance, power, and temperature clarifies how different appliances operate at varying wattages.
esmeralda4
Ok, I'm preparing to get shot down here because maybe this is a really dumb question but here we go...
How does an electric current know to supply more energy (joules per second) to higher wattage appliances?
For example:
At home I can plug a 10W, 50W, 60W or 100W light bulb into a socket and they all work and emit different brightnesses. Why?
What is it about the 100W light bulb that makes it draw more power? It is the resistance? If so does it have more or less than a 60W? Iif it has less R then surely it wouldn't get so hot and therefore so bright and if it had more R then, well, I can't understand why that would make it bright either.
Have I just asked the most stupid question ever on Physics Forum? If anyone can help me clear this up that would be great.
Thanks.
V = IR and Power = VI . Does it answer your question ?
P.S And this is the worst explanation ever :P
You are right in saying that the lower resistance device draws more current. With the house voltage being the same in each case, then the lowest resistance bulb is delivered the most power, i.e., the most heat energy, so it's able to produce the most light energy.
If you lower the resistance then it draws more current. Power = voltage x current
The reason different metal resistances glow differently is almost entirely due to the temperature of their surface, the hotter each tiny glowing area on the surface, the whiter (or bluer) it glows. To cause a small flashlight bulb's filament to glow about as white as does the filament in your large 100W bulb, despite the greatly reduced power in the smaller bulb, the filament is wound smaller and is much thinner and shorter in order to concentrate the heat energy in a small volume of filament metal and raise the local surface temperature to nearly that of the local surface temperature of the larger bulb's much larger filament. The rarified gases in the bulb are designed to reduce the rate at which heat escapes from the bulb, meaning less electrical energy is needed to maintain the high temperature of the glowing filament.
Compare the incandescent light bulb with the heating element on your electric stove. Your stove element is a much lower resistance so draws much greater current and generates a lot more heat energy. But the stove element has much greater volume (it's very thick and also much longer) than the filament in any light globe so the heat energy distributed over the element's much greater surface area fails to raise the local surface temperature much above a dull red glow. The heat is not concentrated in a small space and so fails to raise the temperature nearly as much as happens in a light bulb, before the element's heat escapes to warm the metal of the saucepan resting on it.
I hope that helps you to make the resistance ⇒[/color] power ⇒[/color] heat ⇒[/color] temperature [/color]connection.
:smile:
It is better to remain silent and be thought a fool than to speak out and remove all doubt. Jokes apart, stupid is one who had a question but made no effort to get an answer. Feel free to ask more questions.
:smile:
esmeralda4 said:
Have I just asked the most stupid question ever .
remember: "the only stupid question is the one you never asked"
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
