Thermal radiation between monatomic gases
In a discussion about thermal radiation in monatomic gases like helium, participants explore the mechanisms of photon absorption and emission in isolated containers. The focus is on how thermal photons interact with helium atoms, questioning whether energy transfer occurs through infrequent three-particle collisions or more common two-particle interactions. It is noted that in thermal equilibrium, the density of the surrounding photon gas is higher than that of the helium, which helps resolve the asymmetry in emission and absorption probabilities. The conversation also touches on the intensity of thermal radiation emitted by noble gases, suggesting that at high pressures, gases behave like blackbody emitters, while at lower pressures, they radiate specific frequencies based on atomic orbitals. Overall, the relationship between gas temperature and radiation characteristics is emphasized.
QuasiParticle
Suppose we have two separate containers of helium gas in thermal equilibrium and completely isolated from the rest of the universe. Let's assume the containers are ideal in the sense that they are completely tranparent to all electromagnetic radiation.
Since helium is monatomic, the only degree of freedom (at low enough temperatures) is traslational motion of the atoms. I can understand how collisions of helium atoms create thermal radiation. But how about absorption of the radiation by the other gas. Are the thermal photons absorbed in three-particle collisions (which seem quite infrequent) or do they lose energy in successive two-particle collisions with the atoms?
Science news on Phys.org
After some thought the "problem" with the asymmetry between the emission and absorption probabilities is resolved by increasing the density of the photon gas. That is, in thermal equilibrium the photon gas surrounding the two helium containers has higher particle density than the helium.
But still I wonder if it's possible for the photons to transfer energy to helium atoms in simple photon-atom collisions.
Also the intensity of thermal radiation by helium gas (or other noble gases) would be nice to know. Anybody have any references?
I believe gases act as normal blackbody emitters if they are at a high enough pressure. Otherwise they will normally radiate only specific frequencies that depend on their atomic orbitals. The intensity and frequency spread of the radiation depends directly on the temperature of the gas.
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
