How can I improve my technique to avoid silly errors in my A Level exams?
  • Thread starter Thread starter trollcast
    Errors
To minimize silly mistakes that could impact A Level grades, practicing easier questions to solidify techniques is recommended. Double-checking each step immediately after solving can help catch errors, as can reviewing answers for overall coherence. Some find that revisiting problems after a break, such as an hour later, leads to more reliable solutions, as repeated attempts often reveal mistakes that were initially overlooked. This approach emphasizes the importance of thoroughness and confidence in problem-solving to avoid minor errors that can significantly affect grades.
trollcast
Just wondering what anyone thinks is a good way to try and stop the silly mistakes I keep making that could become a major hinderance next year for my a levels. (Some A Levels have silly grade boundaries and the top boundary can be ~95%, which for a paper out of a total of 75 marks isn't a lot.)
Its not that I don't understand the material, I normally can do the hardest exercises without a problem, its just stupid errors that usually pull me down.
Just a case of doing more practice with some of the easier questions to get my technique down for the different types of questions?
Thanks
AL
Yep, I have the same problem, especially when it comes to combinatorics.
What I tend to do (though this comes naturally to me for some reason) is to effectively double-check each step that I have the slightest lack of confidence about right after I do it, basically redoing it.
I just scan over the problems after I answer them all, to make sure there are no obvious errors.
Yes, check the entire answer until you're sure that it makes sense and you haven't made any obvious errors. Then it should be correct.
I have the same problem. I find if I just double-check it I tend to miss the error unless it is an obvious one. However if I have time (for example in coursework not exams) I repeat the problem a couple of times, an hour or so apart. The 3rd one is usually trustworthy.
After a year of thought, I decided to adjust my ratio for applying the US/EU(+UK) schools. I mostly focused on the US schools before, but things are getting complex and I found out that Europe is also a good place to study. I found some institutes that have professors with similar interests. But gaining the information is much harder than US schools (like you have to contact professors in advance etc). For your information, I have B.S. in engineering (low GPA: 3.2/4.0) in Asia - one SCI...
Bit Britain-specific but I was wondering, what's the best path to take for A-Levels out of the following (I know Y10 seems a bit early to be thinking about A-levels, but my choice will impact what I do this year/ in y11) I (almost) definitely want to do physics at University - so keep that in mind... The subjects that I'm almost definitely going to take are Maths, Further Maths and Physics, and I'm taking a fast track programme which means that I'll be taking AS computer science at the end...
I graduated with a BSc in Physics in 2020. Since there were limited opportunities in my country (mostly teaching), I decided to improve my programming skills and began working in IT, first as a software engineer and later as a quality assurance engineer, where I’ve now spent about 3 years. While this career path has provided financial stability, I’ve realized that my excitement and passion aren’t really there, unlike what I felt when studying or doing research in physics. Working in IT...
