Seeking Help with Electromagnetism: Understanding 'Cancelling the Singularity
The discussion revolves around understanding the integral for the electric field in electromagnetism, particularly the cancellation of singularities in different coordinate systems. The integral is finite even at the singularity due to the volume element's behavior near that point, which cancels the singularity in spherical coordinates. The participants clarify that while spherical coordinates make this cancellation evident, Cartesian coordinates can also handle singularities through different limits of integration. Specifically, in Cartesian coordinates, certain singular integrands remain integrable despite their singularities. The conversation emphasizes the importance of coordinate choice in evaluating integrals in electromagnetism.
kiwakwok
I am currently reading a book about the electromegnetism. When I went through the introductory chapter, there is a small part that I do not understand clearly. Therefore, I hope that I can seek help here.
Quote:
\mathbf{E(r)}=\int\;d\mathbf{r'}\;\frac{\mathbf{r-r'}}{|\mathbf{r-r'}|^3}\rho(\mathbf{r'})​
where d\mathbf{r'} represents the three-dimensional volume element. Note that in spite of the singularity at \mathbf{r=r'}, the integral is finite for a finite charge distribution, even when the point [\itex]\mathbf{r}[\itex] is in the region containing charge. This is because the volume element d\mathbf{r'} in the neighbourhood of a point \mathbf{r'} goes like |\mathbf{r-r'}|^2 for small \mathbf{r-r'}, thereby cancelling the singularity.
I have highlighted the part that I do not fully understand. Does that sentence means in the spherical coordinate, one can write the volume element as d\mathbf{r'}=\tilde{r}^2\sin\theta d\tilde{r}d\theta d\phi where \tilde{r}=|\mathbf{r-r'}|, and the \tilde{r}^2 terms cancel? If so, what if I am not using the spherical coordinate but others such as Cartesian coordinate? There is no \tilde{r}^2 term to do the cancellation.
Thanks in advance for giving me a helping hand.
Reference: P.3, Classical Field Theory by Francis E. Low
hi kiwakwok! :smile:
yes :smile:
then its dx' = dx' dy' dz' :wink:
(the dθ and dφ of course are dimensionless, which is why there*was an added r2)
Thanks tiny-tim. I have one follow-up question:
In spherical coordinate, we can clearly see that the integral above will not blow up even at the singularity. The situation should be the same no matter which coordinate system we use. In the Cartesian coordinates, the integral can be rewritten as
\mathbf{E(x)}=\int dx'dy'dz'\;\rho(\mathbf{x'})\frac{(x-x')\hat{x'}+(y-y')\hat{y'}+(z-z')\hat{z'}}{\left[(x-x')^2+(y-y')^2+(z-z')^2\right]^{3/2}}​
Is there any way that we can know that this integral will not blow up, as what we did previously?
why bother? :confused:
it's a lot easier with spherical coordinates​
I was just interested in such a stupid question xP
Note that if you integrated in spherical coordinates, the limits of integration over a volume centered about the origin would be from 0 to A in terms of r. So if we had a uniform distribution of charge about the origin, we would need the integrand with respect to r to be at least O(1) so that we lost the singularity when evaluating the integration from 0 to A. That is, if the integral was something like 1/r, then we would try to evaluate ln(A)-ln(0) and so on.
But the limits of integration in Cartesian coordinates are different. For a volume about the origin, we would integrate, say z', from -A to A. In this case, an integrand like 1/z^2 is still integrable despite the singularity in the integrand at the origin.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
