How Do You Calculate the Speed of a Falling Chimney's Center of Mass?
  • Thread starter Thread starter NasuSama
    Rotational
16 replies · 4K views
NasuSama
A chimney (length L = 82.6 m, mass M = 2280 kg) cracks at the base, and topples. Assume:
- the chimney behaves like a thin rod, and it does not break apart as it falls
- only gravity (no friction) acts on the chimney as if falls
- the bottom of the chimney tilts but does not move left or right
Find vcm, the linear speed of the center of mass of the chimney just as it hits the ground.
τ = Iα
τ = rF
ω_f² = ω_0² + 2aθ
v = ωr
τ = mgL/2
τ = Iα
mgL/2 = 1/12 * mL² * α
α = 6g/L
ω = √(2αθ) [I was thinking that θ = π/2, but this gives incorrect answer]
v = ωr
= √(2αθ)r
But the whole answer is wrong
The acceleration is not constant, so you cannot use those kinematic formulas for constant acceleration.
Instead of kinematics, think in terms of energy.
Then, I believe it is...
PE = KE
mgL/2 = 1/2 * Iω²
Actually, I used that form and tried to use kinematic as before, but as you just said it's not right.
mgL/2 = ½ * 1/12 * mL²ω²
g = 1/12 * L * ω²
ω = √(12g/L)
v = ωr
= √(12g/L) * L/2
Wait.. As you just said before, I can't use kinematics! But how?
PE = KE
mgL/2 = 1/2 * Iω²
Good!
What's the rotational inertia about the pivot point?
For the chimney acting like the "thin rod", that is 1/3 * mL². Then, we obtain...
mgL/2 = ½ * 1/3 * mL² * ω² [since the rotational axis is at one end of the chimney]
...so ...
g = 1/3 * L * ω²
ω = √(3g/L)
Good!
Doc Al said:
Good!
Continuing from here...
g = 1/3 * L * ω²
ω = √(3g/L)
Then...
v = ωr
But you said that I can't use kinematics. I though that ω is the angular speed, so I need to multiply that value by L/2 to get the result.
I don't understand. I though that ω is the angular speed, right? Then, v is the linear speed.
Which is the key to find? ω or v? I don't even get the point here.
g = 1/3 * L * ω²
ω = √(3g/L)
Then...
v = ωr
Good.
I meant that you couldn't use kinematic formulas for constant acceleration. Of course you can use some kinematics, such as v = ωr. :wink:
Nvm. I believe I get your point when you made the new post.
Right.
You are asked to find the linear speed of the center of mass.
Then, when I substitute all the values in, I get...
v = √(3g/L) * L/2
= √(3 * 9.81/82.6) * 82.6/2
≈ 24.7
v = √(3g/L) * L/2
≈ 24.7
Looks good to me.
Finally, I got it right. Thanks. I checked with the solution key, and I'm actually correct.
Yay! :approve:
