Transform Vector: Real Life Examples
  • Thread starter Thread starter matqkks
    Basis Transform
Transforming a vector from a normal basis (xyz axes) to another basis is essential in various real-life scenarios, such as analyzing forces on inclined planes or when dealing with objects undergoing complex transformations. The concept of a "normal" basis can be subjective, as it may refer to axes fixed to an object's geometry rather than an external observer's perspective. Understanding the flexibility in choosing coordinate bases allows for more effective problem-solving, as different aspects of a problem may be best expressed in different bases. Mastery of coordinate transformation laws is crucial for synthesizing these expressions into a common framework for calculations. A deep appreciation for the arbitrariness of basis choice is necessary for a thorough understanding of mathematics and physics.
matqkks
Why would we want to transform a vector in our normal basis (xyz axes) to another basis? The only situation I can recall is when we are looking at a force applied on an inclined plane. Are there any other real life examples where this may be necessary?
Mathematics news on Phys.org
Why is what you call (xyz) our "normal" base?
For a box or any other object undergoing transformations, rotations and oscillations, perhaps the "normal" base is a set of axis fixed relative to its own geometry, rather than the base set up by an outside obersver?
And, for complex, "real-life" problems, you might encounter that som sub-aspect of the problem is most naturally expressed in one coordinate base, another sub-aspect most easily in another coordinate base.
Thus, the RATIONAL procedure is to develop a flexibility of the mind, and first formulate the sub-aspects in their most natural expressions, and THEN synthesize this into a common basis for calculations, utilizing general laws of coordinate transformation. therefore, you should learn about, and be adept at, those general laws as well.
By the way, if you aren't interested in deepening your understanding of the implications of the essential arbitrariness of a particular choice of base, and thus be motivated in how EVERY legitimate base choice are related to each other through laws of transformation, you really shouldn't bother study either maths or physics.
In short, you display the wrong attitude.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
