Losing a solution of a 1st order ODE?
  • Thread starter Thread starter misogynisticfeminist
    Ode
There is an example in a book regarding DEs which I do not understand. Solve the IVP
y'=y^2-4, y(0)=-2where t is the independent variable
We first solve by separation of variables to arrive at the 1-parameter solution.
-\frac{1}{4}ln (y+2)+\frac{1}{4}ln (y-2)=t+c
Simplifying and expressing the solution explicitly, we find that,
y=2\frac{1+ce^{4t}}{1-ce^{4t}}
Taking the initial condition,
-2=2\frac{1+c}{1-c} which simplifies to,
-1=1.
They said that the solution is wrong because:
we can express the DE as, y'=(y+2)(y-2) and that the when y=-2, and y=2 satisfies this equation (what does it mean?). How do we "preclude" y=-2 and y=-2 before solving starting to solve the DE?
Your initial condition y(0)=2 seems to imply that c = 0, not -1=1?
You can preclude y=-2 simply by noticing that it fails to satisfy the initial condition.
sorry, my initial condition is y(0)=-2. Do we ignore y=-2 because firstly, it doesn't tell us the value of c, and it gives us the illogical -1=1?
Also, do we use the other alternative y=2 because it is the other "alternative" in y'=(y+2)(y-2)? If it is so, why?
The "separable", non-constant solutions involve a division of both sides of the equation with the expression y^{2}-4
But, since you can't divide by zero, you have implicitly assumed that y\neq\pm2
In addition to the non-constant solutions, you've got the constant solutions y_{1}(t)=2,y_{2}(t)=-2
y(0)=-2 is not a valid initial condition.When separating variables YOU ASUMED y\neq 2;y\neq -2 Trying to impose the initial condition to
\frac{y-2}{y+2}=Ce^{4t}
fails...
Daniel.
