If n is an integer, and 3n+2 is even, prove that n is also even
  • Thread starter Thread starter velouria131
    even Integer
The discussion revolves around proving that if n is an integer and 3n + 2 is even, then n must also be even. The method suggested is a contrapositive proof, where the focus shifts to showing that if n is odd, then 3n + 2 is odd. Participants clarify that expressing 3n + 2 as 6k + 5 demonstrates it is indeed odd for any integer k. The proof structure is confirmed, emphasizing that the conclusion follows logically from the established premises. Ultimately, the proof is affirmed as valid, reinforcing the relationship between the evenness of n and the expression 3n + 2.
velouria131
I am coming across hiccups in my proof process. I am given this problem - Prove: if n is an integer and 3n + 2 is even that n is also even. I have to apply a contrapositive proof to this problem. The form is then \negq therefore \negp .The problem becomes - if n is odd, prove that 3n+2 is even.
Work:
Prove - if n is odd, prove that 3n+2 is even.
step 1 - if n is odd, n = 2k+1 for some integer k
step 2 - 3n + 2 = 3(2k+1) + 2 = 6k + 5
step 3 - This is my issue. A contrapositive proof for this problem would give not 'p', or, that 3n+2 is odd when n is odd. Do I now have to show that 6k + 5 is an odd number for any positive integer k? Or, should I just prove that 3n + 2 is odd when n is odd? If I take this route, could I choose another proof method, essentially having a 'proof within a proof'?
I'm assuming that's a typo.
Probably not, but it's better to be safe. An odd number is an integer of form 2m+1. Find m and you are done.
I am still not sure where I would take this proof. I apologize in advance as this is maybe the third proof I have done, and lack serious intution. How would I go about asserting that 6k + 5 is odd for any integer k? Would I do this:
6k + 2 = 2m + 1
m = 3k + 2
...however, this feels like circular logic. Does this mean that 6k+2 takes the form of an odd integer, and is therefore odd?
What about this?
3n+2=2k where k is some integer
n=2(k-1)/3
If n is an integer (given) it has to be even with 2 as a factor.
6k + 2 = 2m + 1
m = 3k + 2
You need to stop being careless with your posting. It's "+5" not "+2".
And yes. We prove something is odd by either
  1. Showing that it is equal to 2m+1 for some integer m, or
  2. Show the number is congruent to 1 (mod 2).
And it's easy enough to show that those two statements amount to the same thing.
rollingstein said:
What about this?
n=2(k-1)/3
That's not a contrapositive proof.
Sorry. Didn't read that requirement. My bad.
P1:If 3n+2 is even then n is also even
P2:Contrapositive of P1: If n is odd then 3n + 2 is odd
n=2k+1 where k=0,1,2,...
3n+2=6k+3+2
= 6k+5
=6k+6-1
=2(3k+3) - 1
= even - 1
= odd
QED?
3n+2 even
=>3n even
=>n even. This is the basic idea.
