Russell's paradox and logical errors in the proof
Russell's paradox presents a contradiction when defining a set R as containing all sets that do not contain themselves. The discussion highlights a logical error in assuming R can simultaneously belong to itself and not belong to itself, leading to a contradiction. Dan argues that both assumptions contradict the definition of R, which is elaborated in his paper. Critics express frustration over needing to read the paper for clarification, emphasizing the need for clearer explanations. The conversation revolves around the complexities of set theory and the implications of self-referential definitions in logic.
DanTeplitskiy
I need your opinion/help, guys.
Well-know American logician H. Curry once expressed the opinion that in spite of the fact that it seemed to be absolutely impossible to explain Russell's paradox in terms of conventional 19th century logic, it may happen in modern days that some error would be identified.
I consider my paper (link below) to give the ultimate answer to this challenge, identifing the one.
https://docs.google.com/file/d/0B_tihhgZ1L4wOUN3aTVFN05sXzQ/edit?usp=sharing
I hope you will become interested and give your valuable opinion on the paper. Such feedback will help me a lot!
The paper is rather small and written in a clear organized way – I do not think it will take more than 30 minutes from a person knowing the very basics of math to get it all.
Thanks a lot in advance!
Dan
P.S. The paper is in English, though, of course, it is not English of an English speaking person.
Dan
Russell's Paradox seems quite straightforward to me. I don't understand what the alleged obscurity is.
Dear ImaLooser,
Have you read pages 2 through 4 of the paper?
Yours,
Dan
I had a quick look at pages 2-4. What is wrong with the following proof: Suppose that ##\{x\,|\,x\notin x\}## is a set, and denote it by R. Since R is a set, the statement ##R\in R## must be either true or false.
If it's true, then the definition of R tells us that ##R\notin R##, and we have a contradiction.
If it's false, then the definition of R tells us that ##R\in R##, and we have a contradiction.[/color]
So regardless of the truth value of ##R\notin R##, we have a contradiction. This forces us to conclude that the statement ##R\notin R## is neither true nor false. This forces us to reject the assumption that ##\{x\,|\,x\notin x\}## is a set. ##\square##
You seem to be rejecting both of colored sentences above, and I don't understand why. To say that ##R\notin R## has a truth value seems very different from saying that "Dan is a legless man who's bleeding severely from his ankle".
Dear Fredrik,
You missed the point. However I can not put it clearer then it is put in the paper. Sorry.
Yours,
Dan
We shouldn't have to read a paper to get a single point. If you want someone to help you, you need to make it easy to do that.
I should also tell you that the forum has a rule against "original research". One of the reasons for that is that we don't want to spend half our time reading through people's papers to see what they did wrong. If your paper is original research, you're already breaking the forum rules. If it's not, and you just want to discuss a detail in a proof, then you should just describe that detail. There's no need to post the whole paper.
Dear Fredrik,
On details:
1. Both assumptions (R∈R is true and R∈R is false) contradict the definition of R (why it is so is elaborated end of page 2 through beginning of page 3).
2. However, in Russell's paradox we use this definition along with these assumptions to make what you call "tells us that R∉R" and "tells us that R∈R" - that is, conclusions in two parts of reasoning.
3. That is, in Russell's paradox we use "contradictory premises". The known logical error, example of which is put in my paper (you mentioned this example).
Yours,
Dan
I still don't understand. Are you saying I made a logical error in the colored sentences above? Or are you just saying that there's a logical error in this:
If ##R=\left\{x\,|\,x\notin x\right\}##, then ##R\in R\leftrightarrow R\notin R##.
I don't see any logical errors. This if-then statement can't be illogical, since the notation ##R=\left\{x\,|\,x\notin x\right\}## by definition means ##\forall x~\left(x\in x\leftrightarrow x\notin x\right)##. So the assumption implies that ##x\in x\leftrightarrow x\notin x## holds for all x. This implies that it holds when x=R. This is a perfectly valid way to find out that the statement ##R=\left\{x\,|\,x\notin x\right\}## can't be true for any set R.
Edit: I made a mistake when I wrote ##\forall x~\left(x\in x\leftrightarrow x\notin x\right)##. It should be ##\forall x~\left(x\in R\leftrightarrow x\notin x\right)##. So the assumption implies that ##x\in R\leftrightarrow x\notin x## holds for all x. In particular, it holds when x=R.
Dear Fredrik,
Yes, you made a logical error in the colored sentences above.
As I am talking about a logical error, that fact that predicate calculus axioms (the language you just used) give us R∈R↔R∉R does not invalidate my reasoning.
Do you understand why both assumptions (R∈R is true and R∈R is false) contradict the definition of R (why it is so is elaborated end of page 2 through beginning of page 3)?
Yours,
Dan
Yes, I do. I haven't studied your argument for it, but it follows from what I meant to say in my previous post. What I actually said was wrong. The notation ##R=\left\{x\,|\,x\notin x\right\}## by definition means ##\forall x~\left(x\in R\leftrightarrow x\notin x\right)##. (In my previous post, I put an x where the R is supposed to be). So the definition of R implies that ##R\in R\leftrightarrow R\notin R##, which is a false statement regardless of the truth value of ##R\in R##.
Dear Fredrik,
If you say you understand my argument without reading it, it makes no sense in further discussion.
Anyway, thanks for your attention!
Yours,
Dan
P.S. I noticed your small error in the previous message. Though, as I understood the whole point it made no sense for me to mention it.
I'm not sure what point the OP is trying to make, but the point that Russell and Whitehead made was that the notion of "defining" includes the notion that the thing being defined exists.
If I say "let S be a square circle", I haven't defined anything. And the basic point of R&W's book is that the string of symbols ##\{x\, |\, x \notin x\}## also doesn't define anything.
I can't be bothered to look up a section reference in R&W's Principia Mathematica, but one of their examples is the meaning (if any) of statements like "the present king of France is bald". I don't see much logical difference between buying the king a toupee or sending the OP's legless man to hospital...
I haven't said that I understand your argument without reading it. I don't even understand what point you're trying to make about Russell's paradox, and this is something I would need to know before I consider studying your paper in detail.
Let me combine what I said in posts #4 and #10, and then you can tell me what you think is wrong with it.
Let ##R## be an arbitrary set. We will prove that ##R\neq\{x\,|\,x\notin x\}## by deriving a contradiction from the assumption that this statement is false. So suppose that ##R=\{x\,|\,x\notin x\}##. This notation by definition means that ##\forall x~\left(x\in R\leftrightarrow x\notin x\right)##. This implies that ##R\in R\leftrightarrow R\notin R##. This contradicts the fact that ##R\in R\leftrightarrow R\notin R## is a false statement regardless of the truth value of ##R\in R##.
Dear AlephZero,
Though I could not see your point the point of the example in the paper was to make the example of "contradictory premises" logical error.
Yours,
Dan
Dear Fredrik,
If you do not read the argument you can not see the point. I am not a wizard :).
Yours,
Dan
If you're not willing to explain what the point of the article is, then why should anyone read it?
Dear Fredrik,
The point of the article is in the abstract :) As usual.
I put here main details of my proof and asked to read a very small portion of the paper for little elaboration.
You did not manage to do it.
Yours,
Dan
What do mean by "contradict the definition"? I think you mean that no set exists that satisfies the definition of your paper's R. That isn't controversial and, in fact, it is part of the content of Russell's Paradox.
Russell's Paradox is only a paradox if we assert that sets whose definitions are given in a very unrestricted way are always mathematical objects that exist. What you need to examine is whether "19 century" set theory did assert that. Or whether it expressly prohibited the definition of a set from being self-referential in some ways.
As to variants of "contradicting" a definiton:
For an assertion to be a definition, it must be possible to express it in the form:
[statement involving the things to be defined] if and only if [statement involving things that have been previously defined].
One may contradict a definition, in the sense that one may disagree with cultural conventions and have the private opinion that [statement involving the things to be defined] should be set equivalent to a different statement.
One may prove that no things exist that make [statement involving things to be defined] true by showing that no things exist that make [statement involving things that have been previously defined] true. Such a proof is not a contradiction of the definition. It merely shows that no things exists that satisfy the definition.
One may assert that a statement involving undefined things cannot be put in the form: [statement involving the undefined things] if an only if [ statement involving only things that have been previously defined]. This asserts that the statement is not a definition. It doesn't contradict a definition that is granted to exist.
Dear Stephen Tashi,
Have you read the small portion of the paper I pointed at before during my discussion with Fredrik (end of page 2 through the beginning of page 3)?
Yours,
Dan
Dear Fredrik, Stephen Tashi and others,
I will try to elaborate on my point a little more.
1. Both assumptions (R∈R is true and R∈R is false) contradict the definition of R (Let R be the set of all sets that are not members of themselves):
1) Assumption R ∈ R contradicts the definition of R because if R ∈ R, R includes a member that is included in itself (R itself is such a member).
Or, symbolically: R ∈ R → ∃ y: y ∈ R ∧ y ∈ y → R ≠ {x: x∉x}: indeed, such y exists as we can take y = R
2) Assumption R ∉ R contradicts the definition of R because if R ∉ R, R does not include a member that is not included in itself (R itself is such a member).
Or, symbolically:R ∉ R → ∃ y: y ∉ R ∧ y ∉ y → R ≠ {x: x∉x}: indeed, such y exists as we can take y = R
2. However, in Russell's paradox we use this definition along with these assumptions to make conclusions in two parts of reasoning:
Suppose R ∈ R. Then, according to its definition, R ∉ R.
Suppose R ∉ R. Then, according to its definition, R ∈ R.
Argument 1
Premise 1: Let R be the set of all sets that are not members of themselves R = {x: x∉x}
Premise 2 (assumption): Suppose R ∈ R.
Conclusion: Then, according to its definition, R ∉ R.
Argument 2
Premise 2 (assumption): Suppose R ∉ R.
Conclusion: Then, according to its definition, R ∈ R.
3. That is, in Russell's paradox we use "contradictory premises". The known logical error, example of which is put in my paper:
Example Argument.
Premise 1: Let Dan be a completely legless man
Premise 2: Suppose, Dan’s right ankle is severely bleeding
Conclusion: Then, according to his definition, Dan should be taken to an emergency for legless people (for his ankle bleeding).
The reasoning on `legless Dan' contains the same logical error as the Russell's paradox does: the second premise contradicts the denition which is the first premise though to make the conclusion both premises are used.
Yours,
Dan
P.S. I did not mean to be rude or arrogant or something...just wanted someone to read the paper. :)
Do you think that Russell's argument rests on the assumptions 'R is a member of R' and 'R is not a member of R'?
If true, that would be bad. And I think i can see, from your summary, why it looks that way. Russell's argument seems to have two parts, and the contradictory assumptions appear in the two parts. But when you understand the logical structure of the argument you should see that these are not premises of his argument.
The relevant "premise" is a disjunction: either R is a member of R or R is not a member of R. This is an instance of a general logical truth. Then the logical structure of the proof is an ' disjunction elimination': if you can show that both disjuncts lead to the same conclusion, then that conclusion follows from the disjunct itself. So first Russell examines what follows from 'R is a member of R' and shows we get a contradiction. Then he examines what follows from 'R is not a member of R' and gets a contradiction. Thus, in either case, there is a contradiction. So 'either R is in R or R is not in R' leads to a contradiction. Problem.
Disjunction elimination can look confusing when written out in linear style, as it can seem as though the disjuncts themselves both figure as premises in the argument.
Dear Yossell,
The reasoning that leads to Russell's paradox (mathematically speaking, the proof of Russell's paradox) :
Or like Fredrik put it in this thread earlier:
the statement R∈R must be either true or false.
if it's true, then the definition of R tells us that R∉R, and we have a contradiction.
If it's false, then the definition of R tells us that R∈R, and we have a contradiction.
has two arguments.
I do not mean that there is nothing else besides these two arguments when we talk about Russell's paradox. We can say at first that the statement R∈R must be either true or false (like Fredrik did). However the two logical arguments in it do exist.
Yours,
Dan
You still are using the idea of "contradicting" a definition. What you actually mean is that no set exists that satisfies the definition of R. There is no contradiction involved in writing definitions of things that cannot exist. (For example, define N to be the largest real number. This defines a number that does not exist, but it isn't a logical paradox.) A definition does not assert the existence of the thing defined. For example, you can define the "multiplicative inverse" of a matrix, but this doesn't assert that all matrices have multiplicative inverses. As assertion that something exists mathematically must be either an assumption or a theorem. Such an assertion is not in the content of what we call a definition.
The fact that no set R exists is only a "paradox" if the axioms you are using includes a statement that says that a set defined as R is defined must exist. Your arguments show that R cannot exist because assuming it exists, contradicts the axiom that "If S is a set and x is an element then either x is a member of S or x is not a member os S". That is a well known fact. However, you haven't dealt with the "paradox" aspect well. You need to look at the historical state of set theory prior to Russell and determine why people thought that an arbitrary definition of a set would always define a set that existed, even if it was only the null set.
The notation S = \{x : P(x)\} is just a convenient version of writing \forall x (x\in S \leftrightarrow P(x)).
The point of Russels paradox is that if there were a set R = \{x : x \notin x\}, it would translate to \forall x (x\in R \leftrightarrow x\notin x) and if this holds for all x, then it certainly holds for a particular choice of x. Let this choice be x = R, then you immediately get R\in R \leftrightarrow R\notin R, which is a contradiction.
This proof uses only one single deductive step: From \forall x P(x) deduce P(y) for any y you like (applied to the special case that P(x) is x\in R \leftrightarrow x\notin x). If you deny Russels paradox, you also deny that this single deductive step is valid reasoning.
Dear Rubi,
I know well that in predicate logic it is one deductive step. I mention it on page 7 of my paper. :)
Rubi, when I talk about "contradictory premises" logical error I talk about logical arguments in Russell's paradox. See my message above (message #20). I do not deny the axioms of predicate logic :)On the fact that we get Russell's paradox in predicate calculus let me quote my own paper here:
It is well-known that we can get R ∈ R ↔ R ∉ R from ∀ x (x ∈ R ↔ x ∉ x) in predicate calculus.
Namely, through a quantifier axiom usually referred as Universal instantiation:
∀ x A → A (a/x), for some term a and where A (a / x) is the result of substituting a for all free
occurrences of x in A.
That is, it can be said that in predicate calculus Russell’s paradox is acquired as the conclusion R ∈ R ↔ R ∉ R from one premise - ∀ x (x ∈ R ↔ x ∉ x).
Though, we can easily see that ultimately R ∉ R is entailed by the set of two sentences: ∀ x (x ∈ R ↔ x ∉ R) and R ∈ R, while R ∈ R is entailed by the set of two sentences: ∀ x (x ∈ R ↔ x ∉ R) and R ∉ R. Indeed, let us use the importation:
∀ x (x ∈ R ↔ x ∉ x) → (R ∈ R → R ∉ R) is equivalent to (∀ x (x ∈ R ↔ x ∉ x) ∧ R ∈ R) → R ∉ R
∀ x (x ∈ R ↔ x ∉ x) → (R ∉ R → R ∈ R) is equivalent to (∀ x (x ∈ R ↔ x ∉ x) ∧ R ∉ R) → R ∈ R.
As we could clearly see from the proof of Contradictory premises theorem,
these pairs of sentences contain the "hidden" contradiction within each pair.
Yours,
Dan
Dear Stephen Tashi,
My arguments are to demonstrate that there is a logical error in each of the two logical arguments in Russell's paradox. :) Please see my message#20 in this thread :)
Yours,
Dan
Dear Dan,
I don't understand what you are trying to say. I have shown (using conventional predicate logic) that the statement \exists R\forall x (x\in R \leftrightarrow x\notin x) implies a contradiction ((\exists R\forall x (x\in R \leftrightarrow x\notin x))\rightarrow\bot).
Now i need you to answer the following question: Do you agree that this derivation is correct?
If the answer is no: Which step in the derivation is wrong? (You should be able to answer this question in one sentence, because you only need to point at one single step!) To make it even more clear, here are is the derivation again:
1. \exists R\forall x (x\in R \leftrightarrow x\notin x)
2. \forall x (x\in S \leftrightarrow x\notin x) (from 1; if there exists such an R, i can assign it to an unused variable)
3. S\in S \leftrightarrow S\notin S (from 2; if it holds for all x, it also holds for R)
4. \bot (from 3; it's a contradiction)
5. (\exists R\forall x (x\in R \leftrightarrow x\notin x))\rightarrow\bot (by the decuction theorem)
If the answer is yes, you have the following options: Either you accept that \exists R\forall x (x\in R \leftrightarrow x\notin x) is false or you are willing to accept contradictory statements in your axiomatic system. Which one of these options do you choose?
Dear Rubi,
You correctly applied the axiom of predicate calculus.
Have you read my message #20 above? Have you understood everyithing there?
Yours,
Dan
Yes, i have.
No i haven't. That's why i want you to answer my question. I'm not willing to spend more time on this if you refuse to answer my questions.
Dear Rubi,
I answered your first question as well as I could.
"∃R∀x(x∈R↔x∉x) is false" - this is correct, of course :) There is no such R :). I am not making any alternative "my" axiomatic system )))).
What exactly (which line) have you failed to understand in my message#20?
Yours,
Dan
  • #31
Then we are done, because we came to the same conclusion as Russel did. There is no way to define the set R = \{x:x\notin x\} in usual predicate logic without implying a contradiction. This is exactly Russels paradox.
"Both assumptions (R∈R is true and R∈R is false) contradict the definition of R" doesn't make sense, because you can't contradict a definition. Your use of language is wrong.
  • #32
Dear Rubi,
Russell's paradox is like:
Let R be the set of all sets that are not members of themselves. Then it is a member of itself if and only if it is not a member of itself. - paradoxical incoherence.
The usual conclusion that we make from the paradox is that there is no such R.
"Let ABC be a triangle. Suppose it has four angles." :) - well, this is a sort of joke ))
If seriously, enter "contradicts the definition" into google serach and find some math texts ;)
Yours,
Dan
  • #33
We proved this and you already said that you accept the derivation.
That is true. If a statement leads to a contradiction, then it must be false. You also agreed on this.
If you really agree that one can derive a contradiction from the assumption of the existence of the Russel set, then I don't see what problems remain.
What I was trying to say was that it is irrelevant for the proof whether something contradicts the definition of the Russel set. R\in R is a well-formed formula and thus you are allowed to use it according to the rules of predicate logic.
  • #34
Dear Rubi,
I said you correctly used the axiom of predicate logic ))
Actually, I suspect you did not even try to read my message#20 after the sentence "Both assumptions (R∈R is true and R∈R is false) contradict the definition of R (Let R be the set of all sets that are not members of themselves)"
Which makes further discussion with you senseless ))
Yours,
Dan
  • #35
So either you agree that the existence of R implies R\in R\leftrightarrow R\notin R or you claim that using predicate logic is not a valid way of reasoning. I have still not found out, which of these two options you advocate.
I have read it, but i don't see what the problem is. Let's look at this part for example:
Argument 1
We can easily phrase this in predicate logic:
1. \forall x (x \in R \leftrightarrow x\notin x) (this is your first premise)
2. R \in R (this is your second premise)
3. R \in R \leftrightarrow R\notin R (from 1 by setting x=R)
4. R \notin R (from 2 and 3 by modus ponens)
This is completely valid reasoning. (\forall x (x \in R \leftrightarrow x\notin x))\rightarrow R\notin R is a theorem.
  • #36
Dear Rubi,
Yes, in predicate logic Argument 1 is a theorem. I know it ))
My point is that assumption R ∈ R contradicts the definition of R because if R ∈ R, R includes a member that is included in itself (R itself is such a member).
That is the second premise contradicts the first one. "Contradictory premises" logical error.
Like in the below:
The reasoning on `legless Dan' contains the same logical error as the Russell's paradox does: the second premise contradicts the definition which is the first premise though to make the conclusion both premises are used.
Yours,
Dan
  • #37
And why is that a bad thing? You can assume whatever you want. The entire point of Russels paradox is to show that you end up with contradictions. If you don't want contradictions, then just don't assume that the Russel set exists.
This is just yet another contradiction that you can derive if you assume the existence of the Russel set. Remember that if you have one contradiction in your axioms, you can derive every statement that you can think of.
  • #38
Can you give a reference where Curry said that?
  • #39
Dear Micromass,
Hi! Remember me? ))
The reference is in the reference section of the paper)) It is a book by a Russian logician Ivin. He mentions this. By the way I am not quoting.
Yours,
Dan
  • #40
Dear Rubi,
It is a logical error to make conclusion such a way )) Which is not a good thing )))
Like in the below:
Well, if you consider the example to be OK, Russell's paradox is OK as well :smile:
Yours,
Dan
  • #41
DanTeplitskiy said:
It is a logical error )) Which is not a good thing )))
It just shows that you can derive logical if you assume the existence of the Russel set, you can derive contradictions. This is nothing new. It has been known for more than 100 years now. The conclusion is that you should not assume the existence of the Russel set or any axiom that implies the existence of the Russel set.
Like in the below:
You just showed that if you assume contradictory statements, then you end up with contradictions.
Well, if you consider the example is OK, Russell's paradox is OK as well :smile:
Depends on what you mean by "Russel's paradox is OK". If you mean that one can safely assume the existence of the Russel set, then it's not OK. But if you mean that the existence of the Russel set implies contradictions, then it's perfectly OK, because nobody forces us to assume it's existence. We can just deny it and everyone is happy until someone finds a new paradox. You can easily disprove the existence of the Russel set in modern set theory.
  • #42
Dear Rubi,
Reasoning on legless Dan is an example of "contradictory premises" logical error.
The same one as in Russell's paradox.
Yours,
Dan
  • #43
Let's see if I understand what this thread is about...
We all agree that the following statement is a theorem: There's no set ##R## such that ##R=\{x\,|\,x\notin x\}##.
(I proved it in #13, and rubi did it in several of his posts).
Dan is arguing that some attempted proofs are flawed, because they're making two contradictory assumptions. The two assumptions are ##R\in R## and ##R\notin R##.
In that case, I think Dan's concern is very easy to answer: No one is assuming that both of those statements are true.
Dan, I don't know how can you continue to claim that there's an error in "Russell's paradox" after agreeing that there are valid ways to prove the theorem. Do you mean something different from that theorem when you say "Russell's paradox"?
  • #44
You can apply the deductive rules of predicate logic to any set of axioms you like. Some choices for your axioms might give you contradictions, though. The conclusion is that you should choose other axioms. This is exactly what happened: We found that naive set theory implies a contradiction (Russels paradox), so we rejected it and invented ZFC instead. Now we hope that nobody finds a contradiction in ZFC anymore.
  • #45
Dan, I'm giving you one last chance to answer what I said in post #43 before I close the thread. Don't copy and paste from earlier. Is your entire paper, and this entire thread, based on the idea that some people are assuming both ##R\in R## and ##R\notin R##?
  • #46
Dear Fredrik,
No! You missed the point, sorry. Please try to read my message#20 ))
I thought you missed it - that is why I wanted to put it here again...
Yours,
Dan
  • #47
I read post #20 again. OK, I think I see what you're saying: The two premises that you say are contradictory are not ##R\in R## and ##R\notin R##. It's (in argument 1) ##R\in R## and ##R=\{x\,|\,x\notin x\}##.
If that's what you meant, then my answer is that this is irrelevant, since no one considers argument 1 (or argument 2) to be a complete proof. ##R\in R## is not one of the assumptions that go into the proof. There's only one assumption (which is made only to obtain a contradiction), and that is that ##R=\{x\,|\,x\notin x\}##.
Also, no one is saying that arguments 1 and 2 together prove the theorem, because then we'd have three assumptions that don't agree with each other.
Do you agree that there is a valid proof of the theorem I stated in #43? (I'm thinking of the proof I posted in #13 and the similar proofs posted by rubi).
  • #48
DanTeplitskiy said:
Like in the below:
These are not well-formed formula's, so I don't see the point of considering these statements. They imply nothing about math. Math only deals with well-formed formulas.
  • #49
Dear Fredric,
Nor do I! My point is that each of them separately is a fallacious, that is, containing a logical error, argument.
Well it depends on what you mean by valid...
As to me it contains logical errors but at the same time it is a theorem in predicate logic (that is quite deducable, valid and correct thing in this formal system).
Yours,
Dan
  • #50
Dear Micromass,
This is an example of the logical error.
I could not invent the example of this logical error in math different from Russell's paradox-like things...
Yours,
Dan
