Is this a solid way to mark an exam on a Mathematical subject?
In an Engineering course, students typically receive partial credit for demonstrating a solid understanding of theory, even if their final solutions contain significant errors. However, in a recent exam for a Mathematics subject, a student received only 20% for their work, which was unexpected given their theoretical understanding. The grading approach in this Mathematics department appears to prioritize the correctness of the final solution over the theoretical foundation, leading to concerns about fairness and leniency in grading practices. The student questions whether this strict grading is standard or excessively harsh, suggesting that while it may be justifiable academically, it seems extreme compared to the more lenient grading in Engineering courses. The discussion highlights a tension between theoretical understanding and the necessity for accuracy in mathematical solutions, with references to the importance of precision in engineering contexts.
cdux
In an Engineering course I was used to being rewarded for proving a good understanding of theory. For example, if I explained a basis of the following solution, it would still give some rewards, even if the solution itself had major computing errors or even if it was partially mathematically wrong.
On my last exam on a Mathematical subject (based on a non-Engineering Mathematics department) I was given a 20% when I expected around 50-60%. My understanding is that they rewarded 0% to the theory preceding a solution, if the solution was at least partially mathematically incorrect.
Is that fair or normal?
I suspect that it's not "illegal", but I believe it stretches the lengths of lack of leniency. I'm sure they could prove it's legit to their colleagues but at the same time it's a bit extreme that I suspect they could even get away with a 70%. So with a wiggle room between 20-30% and 60-70%, it seems a bit extreme going for the lowest end.
Then again, I almost hope I'm not right since it would mean I'm not 'targetted', or at least the whole class isn't ('cause it was probably relatively consistent)
A legendary engineering professor once said "Make a sign error, build bridge upside down, and people and cars fall off. No credit."
Likes 1 person
Bit Britain-specific but I was wondering, what's the best path to take for A-Levels out of the following (I know Y10 seems a bit early to be thinking about A-levels, but my choice will impact what I do this year/ in y11) I (almost) definitely want to do physics at University - so keep that in mind... The subjects that I'm almost definitely going to take are Maths, Further Maths and Physics, and I'm taking a fast track programme which means that I'll be taking AS computer science at the end...
After a year of thought, I decided to adjust my ratio for applying the US/EU(+UK) schools. I mostly focused on the US schools before, but things are getting complex and I found out that Europe is also a good place to study. I found some institutes that have professors with similar interests. But gaining the information is much harder than US schools (like you have to contact professors in advance etc). For your information, I have B.S. in engineering (low GPA: 3.2/4.0) in Asia - one SCI...
I graduated with a BSc in Physics in 2020. Since there were limited opportunities in my country (mostly teaching), I decided to improve my programming skills and began working in IT, first as a software engineer and later as a quality assurance engineer, where I’ve now spent about 3 years. While this career path has provided financial stability, I’ve realized that my excitement and passion aren’t really there, unlike what I felt when studying or doing research in physics. Working in IT...
