Irrational numbers could they be more
The discussion centers on the nature of irrational numbers, questioning whether they should be viewed as distinct values or as functions that yield values based on input. Participants argue about the implications of defining numbers, particularly irrational ones like pi, as functions rather than fixed values, leading to debates on mathematical definitions and the representation of numbers. There is a contention regarding the existence of infinite complexity within finite space and the quantization of reality, with some asserting that such beliefs contradict established mathematical principles. The conversation highlights misunderstandings of mathematical terminology and the foundational concepts of functions and numbers. Ultimately, the dialogue reflects deep philosophical inquiries into the nature of mathematics and reality.
Pejeu
consistently thought of as actually emergent functions that take the desired accuracy as input?
As them being numbers would imply the apparently paradoxical concept that infinite complexity can exist in a finite volume of space.
Mathematics news on Phys.org
Those words, in that order, make precisely no sense at all. They're not even wrong.
I'm not entirely sure what you're trying to say, but consider this: Almost all real numbers are irrational. If your worldview can't accommodate their existence, then your worldview is wrong.
"more" than what?
What does that mean?
Numbers are not physical objects in space.
mfb said:
"more" than what?
Shouldn't a number have a particular, unique, set value?
Isn't that a defining characteristic of what a number is? Isn't that intrinsic to the concept of a number?
A function doesn't have one particular, unique value.
You can aproximative pi by various different methods, which close in on the value (what value? there is no value) at different rates.
So isn't there some underlying mathematical mechanism here whose output is the one merely captured by different aproximations?
Why should pi be thought of as a number (a value) instead of as a rule or function/computation method? A function that receives the desired degree of accuracy as its argument.
Yet that's what they're used to represent. Quantities, amounts, sizes. Distances, masses, charges etc. Scalars, vectors, tensors etc.
And isn't this their purpose? To represent amounts or concepts involving amounts (ratios, for example)?
What amount or ratio of amounts does pi represent?
But beyond that, shouldn't numbers, by definition, have a set, known value?
Do we say that a function that tends asymptotically towards a limit has that limit as its value?
Yet irrational numbers aren't even asymptotic limits.
Or do we say that a function has a particular value at all?
No, because the value of the function depends on the input.
If irrational numbers may be thought of as functions so too may real numbers with repeating decimals aren't numbers either but actually functions as well.
My world view is that space, time and everything else is discrete, quantized.
And that I have no clue how reality works or what it looks like at its fundamental scale.
Or how and why objects, particles, waves etc. skip from one discrete position in space-time to a particular other position or what the fundamental lattice of space and time looks like, what shape its quanta are (i doubt it's cubical).
But that this somehow probably accounts for quantum weirdness.
Pi has a precise value. Why do you think it doesn't? Or do you mean its representation should be unique (i.e. that it should be represented by a unique symbol)? This is clearly untrue: 0.333... and 1/3 represent the same number, for instance.
"Number" has no definition in mathematics; it's a colloquialism.
The ratio of a circle's circumference to its diameter.
Of course they are. I can construct a sequence of rational numbers converging to any irrational number you like (this is, in fact, where irrational numbers "come from" when constructing the reals).
You don't seem to understand what a function is either. A function ##f:X \rightarrow Y## is a subset ##f \subset X \times Y## such that, for every ##x \in X##, there exists exactly one ##y \in Y## such that ##(x,y) \in f##.
Now tell me, how is an irrational number a function?
These two statements are mutually contradictory.
There is no evidence that either space or time is quantized but you say that they ARE, then you say you don't know what things are like at the fundamental scale after having just said that you believe they are quantized. So if you don't know what they are like, why do you think they are quantized?
1. No, I didn't say that they are. I said that's my worldview.
That is my worldview because ascribing to a continuous spacetime implies infinite complexity in a finite volume of space.
As that seems paradoxical to me I am forced to assume the alternative. Thus my worldview.
2. I said I don't know how spacetime is quantized.
I also said I don't know what movement at this scale is like or how or even why it occurs.
It might be something akin to what makes fliers in conway's game of life move and how they move.
We might be made of those fliers.
Electrons might be fliers like that, for instance.
Maybe that's also why they're waves of probability to us, looking down from our scale. Because they occupy more than a single quanta of space.
The fliers in Conway's game of life change shape as they move through the lattice. Maybe so do electrons as they orbit the nucleus.
This could be true in physics (we don't know).
It is certainly wrong in mathematics.
What is that value? Write it out in its entirety.
Reread my post, I conceded at the end that by my logic real numbers with predictably repeating decimals like 1/3 may also be regarded as functions.
It really wasn't much of a concession for me to make at all. I agree full heartedly with it.
Then this whole discussion is rather pointless, isn't it?
Well for this circle that ratio seems to me to be 2.4.
Or is this not a circle?
What's the difference between a circle and this? Is it a quantitative difference or a qualitative one?
They're both enclosed, at least. A circle and my contraption above.
They're also both convex.
What other qualitative differences can there be?
I can't give an irrational number. Not by value, at least.
How do you pass a function by value?
You don't, you pass it by description, by outlying the algorithm contained therein.
An irrational number is not a value but a computation algorithm. A function. A method of computing something whose value depends on the input provided.
Computation is meaningless when no input is provided or input is never changed.
Except as a way to save on memory usage at the cost of processing time or reduce the likelihood of value corruption (by recomputing the result each time it's needed, to the degree of precision required). However the memory storing the algorithm itself may also be subject to corruption.
I must say it really does seem to me you're intent on ridiculing me or my views instead of earnestly discussing them just in case they're not self-evidently wrong, just a different.
I think lots of what we colloquially call numbers, as number nine put it, are really functions.
I don't think it's wrong to call a function a function. I mean, it may be wrong by fiat.
I think when we're computing or manipulating expressions we're actually engaging in a sort of fundamental programming.
We are writing an algorithm for computing values depending on values received as inputs, not computing a value outright.
I think analytical mathematics is about this.
Writing algorithms to compute stuff.
Or rather simplifying and combining existing algorithms.
I thing a mathematical function or expression is basically an algorithm. The results of algorithms vary. They are not unique. That would be pointless. And that's why you don't call an algorithm by its value. Because it has no particular value.
This becomes more clear if and when you try to write a parser for mathematical language. You realize mathematics is actually metaprogramming.
I think there is no real reason why it would be wrong to view irrational numbers and real numbers with repeating decimals as functions.
Except for inferred dogma.
It's value is denoted precisely by ##\pi##.
1/3 is not a mapping between sets. It is not a function.
You are using words without understanding their meaning.
Not at all, the terms "rational number" and "irrational" have precise definitions with respect to the reals.
No, it isn't. A circle is the graph of an equation of the form ##(x - a)^2 + (b - y)^2 = r^2##.
Specify the sets ##X## and ##Y## as well as the mapping ##f:X \rightarrow Y## such that ##\sqrt{2} = f##.
What you're suggesting is not an "alternative explanation". It is demonstrably nonsense and suggests that you have never studied mathematics beyond a trivial high school level, and, worse, are incapable of dealing with concepts that even slightly violate your naive intuition.
You don't even understand what a function is, so clearly you have no basis to make this statement.
EDIT: After reading this thread, it is quite clear that you are a crank. This thread should be locked.
You're being purposely disingenuous. That's a wildcard, not a value.
A function pointer, if you will.
Just as a or b may be regarded as pointers (or references, placeholders, if you prefer) to values or numbers.
Or maybe I'm thinking of a deeper meaning that transpires subtly different but essentially the same through different definitions.
Does 1/3 not refer to the instruction to execute the algorithm known as "division" on the arguments '1' and '3'?
Is it or is it not an explicit command to perform an algorithm on specific values for arguments?
Is division not an algorithm? Is division a number?
Please take a little time to think about it before you reply as you're being needlessly argumentative and you're not really providing any new rebuttals, just rehashing your first, superficial ones.
Your rebuttals are meaningless.
So that isn't a circle.
Explain why, please. Don't repeat what a circle is, explain why that one isn't.
So the square root operation is now a number as well?
I'm beginning to wonder what a number isn't.
Number Nine said:
Your post is crankery, and this thread should be locked.
Why? Because you can't successfully argue your assertions?
Pejeu, much of what you're saying (the emphasis on representations, algorithms, converging approximations) leads me to believe that you're coming at this from a computer science perspective. Assuming that you are, I'll offer up two thoughts:
1) The mathematical theory of numbers predates modern computing by centuries. There's an enormous body of knowledge out there that you can take advantage of. This isn't to say you should just swallow it uncritically, it's more that you cannot improve on what we already have if you don't know what we have already have.
2) Although real computers must represent numbers in a finite number of bits, and therefore cannot represent all the numbers on the number line, you should not confuse that with the problems we have finding finite-length encodings of the irrational numbers. It's true that most modern processors interpret the bit pattern 00111111100000000000000000000000 as an exact 1.0, but the CPU designer could have chosen to assign that bit pattern to the number ##\sqrt{2}## or ##\pi## instead (this would be a bad idea as the resulting design would be harder to implement and less useful, but there's nothing inherently impossible about it).
Pejeu said:
Its value is denoted precisely by π.
It is neither. As the word "denoted" suggests, it is a symbol used to name a particular member of the set of real numbers, just as is "1" or "3/5".
Pejeu,
I am closing this thread. It is clear that you are just here to discuss your personal theory, not learn anything. This in spite of the fact that you have much to learn.
Integral
