How is the tension equal in both sides of the string
  • Thread starter Thread starter Miraj Kayastha
    String Tension
Tension in a string over a pulley remains equal on both sides, even with different masses attached, due to the principles of mechanics. When the system is in motion, the same force acts on both masses, resulting in acceleration rather than equilibrium. If the pulley is considered massless and frictionless, it does not introduce additional forces, ensuring that tension remains constant throughout the string. The force on the pulley is twice the tension because it must remain in equilibrium despite the acceleration of the masses. This understanding hinges on the assumption that the pulley does not add extra forces to the system.
Miraj Kayastha
How is the tension equal in both sides of the string, if the string is over a pulley with two different masses attached to its sides?
The smaller mass accelerates up, which requires more force than the just the weight. On the other side its the opposite.
Can you explain what you mean by "On the other side its the opposite."
The greater mass accelerates down, which requires less force in the rope than the weight.
The same force acts on both masses but they are not in equilibrium so there is acceleration. If the pulley is massless and frictionless, there can be no extra force on one side or the other of the string length - so the forces must be equal. The force on the pulley will be less than the sum of the weights because the CM of the two masses is accelerating downwards.
I did not get you, can you explain in a different way please
How's this?
If there were two rockets, pulling at either end of a string then would not the tension be the same in either direction and all along the ideal string? (That's the basis for all the Mechanics we ever use.)
Merely putting a pulley in the way and re-directing the forces, there is nothing to change that. The force on the pulley will be twice the tension because the pulley is not accelerating and must be in equilibrium.
Likes yucheng
i want to know whether it is an assumption or not
The assumption is:
