Question on Pearson's Chi-squared test
  • Thread starter Thread starter mnb96
    Chi-squared Test
Pearson's Chi-squared test formula evaluates the goodness of fit by comparing observed counts to expected counts, assuming that the variance of the random variables equals their expected values. This assumption is particularly valid for distributions like Poisson and Gamma, where variance and mean are numerically equal. The discussion highlights that the test is applicable to multinomial distributions, which arise when counting observations in defined categories or "cells." It is emphasized that the Chi-squared test requires a sufficiently large number of trials for accurate results. Overall, the interpretation of the test relies on understanding the distribution of the underlying random variables.
mnb96
Hello,
I was trying to interpret the formula of Pearson's Chi-squared test:
\chi^2 = \sum_{i=1}^{n} \frac{(O_i - E_i)^2}{E_i}
I thought that if we assume that each O_i is an observation of the random variable X_i, then the above formula essentially considers the sum-of-squares of n standardized random variables Y_i=\frac{X_i-\mu_i}{\sigma_i}. In fact, if such random variables are Y_i \sim N(0,1), then the random variable S = \sum_{i=1}^n Y_i^2 follows a \chi^2-distribution. Thus, the formula of the Chi-squared test would essentially evaluate the probability \mathrm{P}\left( S = \chi^2 \right), and of course compare it to some chosen P-value.
My question is about the standardization of the random variables X_i.
If my interpretation above is correct, then Pearson's Chi-squared test somehow assumes that each random variable X_i has variance equal to its expected value, that is: \sigma_i^2 = \mu_i
Why so?
Can anybody explain why we would need to assume that variance and expected values are numerically equal? That condition is satisfied only for some distributions like Poisson and Gamma (with \theta=1). Why such a restriction?
The O_i are supposed to be a count of how many observations of a random variable fall within a "cell". How are you are defining the ith cell?
I see! That is an important observation. It probably means that the random variables X_i are supposed to follow a multinomial distribution.
For instance, if we have only one cell, then X_1 could be the amount of successes out of m independent trials of some experiment. Thus, X_1 would follow a binomial distribution, which in fact approaches a Poisson distribution for m large, and which has \sigma^2=\mu=\lambda.
If the above reasoning is correct, then Pearson's Chi-squared test should work only when the number of trials is sufficiently large.
I'm not sure what you mean by that statement.
The test can be applied to repeated independent samples of a single random variable. The single random variable can have any distribution. It is only necessary to define the cells so that they partition the range of the random variable.
Likes 1 person
Hi Stephen, and thanks for your help!
What I meant, is that X_i is a random variable that "counts" the number of observations that happened to fall into the i-th cell. For instance, if we consider a continuous random variable Z having some unknown probability density function, and we partition the real line into two cells corresponding to the events: Z\geq 10 (=success) and Z< 10 (=failure), then the two events will have probabilities p and (1-p).
We can sample the random variable Z many times, say n times.
Now, X_1 is the random variable that keeps the total counts of successes, thus X_1 follows a binomial distribution, i.e. X_1\sim B(n,p).
I thought that if we extend this reasoning to k cells, then the vector of random variables (X_1,\ldots,X_k) should follow a multinomial distribution, i.e. (X_1,\ldots,X_k) \sim M(n;p_1,\ldots,p_k).
Or am I misunderstanding something?
