Calculate Energy Applied to Steel Slab
To calculate the energy applied to a slab of steel with a temperature rise described by the equation -13t + 5t^2 + 10*sin(3ωt), the energy can be determined using the formula mc(dT), where m is the mass, c is the specific heat, and dT is the change in temperature. The derivative of the temperature function, dT/dt, is found to be 13 + 10t + 30ω*cos(3ωt). The discussion raises the question of whether mass (m) and specific heat (c) are constant throughout the process. Clarification on the constancy of these parameters is essential for accurate energy calculations. Understanding these variables is crucial for applying the energy equation effectively.
debo22
I want to calculate the energy applied to a slab of steel with a temperature rise that varying with time (t) as -
13t + 5t^2 + 10* sin (3ωt)
The energy applied to the system is calculated by mc (dT) equation where
m mass of the slab
c specific heat
dT change in temperature
Science news on Phys.org
Are m and c constant?
Then dt= 13+ 10t+ 30\omega cos(3\omega t), of course.
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
