What is the Fraction of One Point Compared to an Infinite Line?
  • Thread starter Thread starter CrossboneSRB
    Discussion
The discussion centers on the concept of comparing a single point to an infinite line, concluding that the fraction of one point among infinite points is effectively 0, as a point has no length. It emphasizes that length is calculated based on the distance between two points, not by counting infinite points within an interval. The conversation also touches on the area of contact between a perfectly round object and a flat surface, asserting that for a sphere, the area of contact is zero due to only one point touching. Additionally, it clarifies that division by infinity is not valid in standard arithmetic, reinforcing that infinity is not a conventional number. Overall, the thread explores the mathematical implications of points and infinity in geometry.
CrossboneSRB
So here's a question for you, if on a line we chose one point, then what is the fraction of this point compared to the line?
I think we all agree that between two points there are infinite amount of other points, correct? So what fraction of a line is one point among infinite others? Isn't it 1/∞?
Here's another question, if a perfectly round object is placed on perfectly flat surface, what is the area of contact?
Mathematics news on Phys.org
0. The "length" of a single point is 0.
No, because we don't calculate length on the basis of how many points are in an interval. We calculate length by subtracting the position of the point on the left from the position of the point on the right. The length of an interval [a, b] between two points (assuming a < b) is b - a.
The ratio of the "length" of a point to the length of the line segment [a, b] is 0/(b - a) = 0.
In any case, division by ∞ is not allowed.
Your question isn't very precise. A circular disk is a perfectly round object, so the area of contact would be the area of the disk.
If by "perfectly round object" you mean a sphere, there is only one point of contact, so the area of contact would be zero for reasons similar to what I already gave.
Infinity cannot be treated as a normal integer or real number. It is not part of one of these sets of numbers. In that sense 1/ꝏ is meaningless.
You can use the infinity concept in limits. Going to infinity means taken larger and larger values (ꝏ is not a number that can ever reach)
The limit of 1/x as x approaches Infinity is: 0For the second question: when a plane "touches" a sphere they have one point in common. The area of contact is therefore 0
The concept of division by infinity can also be made rigorous, instead of using limits, by considering complex infinity on the Riemann sphere.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
