|1s> -> |2p> transition probabilities
1 reply · 4K views
cscott
A hydrogen atom is placed in a time-dependent homogeneous electric field given by [itex]\epsilon = \epsilon_0 (t^2 + \tau^2)^{-1}[/itex] where [itex]\epsilon_0,\tau[/itex] are constants. If the atom is in the ground state at [itex]t=-\inf[/itex], obtain the probability that it ill be found in a 2p state at [itex]t=\inf[/itex]. Assume that the electric field is along the [itex]\hat{z}[/itex] direction.
[tex]\dot{|2p>} = \int_{\inf}^{\inf} H'_{2p,1s} e^{-i \omega_{2p,1s}} dt[/tex]
[tex]H'_{2p,1s} = <2p|H'|1s>[/tex]
The attempt at a solution
Firstly I'm confused with the assumption of field direction and how I get it into the solution. Maybe this is the source of my troubles...
By taking [itex]H'(t)= q\epsilon_0 (t^2 + \tau^2)^{-1}[/itex] I get zero for a transition between [itex]|1s>[/itex] and [itex]|2p0>, |2p\pm1>[/itex] because I get Hamiltonian elements of zero.
[itex]|2p0>[/itex] has a [itex]\cos \theta[/itex] factor so upon integration in spherical,
[tex]\int_0^\pi \sin \theta d\theta \cos \theta = 0[/tex]
and [itex]|2p\pm 1>[/itex] has the [itex]e^{\pm i\phi}[/itex] factor,
[tex]\int_0^{2\pi} e^{\pm i\phi} d\phi = 0[/tex]
Am I simply right or really missing something? The question gives the time integral result so it seems like Hamiltonian elements shouldn't be zero...
I'm using the wavefunctions from here: http://hyperphysics.phy-astr.gsu.edu/hbase/quantum/hydwf.html#c3
The interaction term in the Hamiltonian should be such that the electron couples to the electric potential. The resulting matrix elements will no longer vanish.
