1st order non homogenous DE problem solving
  • Level: Undergrad
  • Thread starter Somefantastik
    Problem solving
9 replies · 4K views · last reply
Somefantastik
In my notes, the prof wrote x' = x + sin(t), x(0) = x0
He did not go through the solution, only wrote that the solution is
x(t,x0) = x0et + et/2 - 1/2(sin(t) + cos(t))
I verified this is correct by substituting.
So when I try to solve this DE, here's what happens:
[tex]{\frac{dx}{dy} \ - \ x = \ sin(t)[/tex]
integrating factor is e-t
[tex]\int \frac{d}{dt} \ (e^{-t}x) = \int e^{-t} \ sin(t) \ dt =>[/tex]
[tex]e^{-t} \ x \ = \ \int e^{-t} \ sin(t) \ dt \ = \ -e^{-t} \ cos(t) \ - \ \int cos(t) \ e^{-t} \ dt \ = \ -e^{-t} \ cos(t) - \left( -e^{-t} \ + \int sin(t) \ e^{-t} \ dt \right)[/tex]
[tex]x = -(1/2)cos(t) + (1/2)sin(t)[/tex]
So I'm close, but where did I lose my e-t's ?
The solution to a non-homogeneous ODE is in the following form:
x = XH + Xsp
Where XH is the general solution to the corresponding homogeneous equation and Xsp is a specific solution to the given non-homogeneous ODE. You have found a specific solution, and you just need to solve the homogeneous equation dx/dt - x = 0 to obtain the XH.
You have e-x on both sides of the equation and they cancel out. Specifically, you get e-tx= -(1/2)e-t(cos(t)- sin(t)) by integration, then the "e-t" on each side cancel.
I understand they cancel; my question referred to the fact that the prof's answer included e to the POSITIVE t and my answer included no e^t's at all.
so I would solve dx/dt - x = 0 the same way that I solved dx/dt = x + sin(t), and then I should add that result with the particular solution and that is my general solution?
Ok so x' = x would have to be x = et.
That gives me x = et - 1/2(sin(t) + cos(t)). It still does not match his final solution of
x(t,x0) = x0et + (1/2)et - 1/2(sin(t) + cos(t))
Any thoughts? I bet that I am misunderstand how to apply x(0) = x0
For one thing I've been forgetting those constants from indefinite integration. I think my specific solution should look more like
[tex] x = -(1/2)cos(t) + (1/2)sin(t) + c(1/2) e^{t}[/tex]
so I guess all that's left if helping me figure out how the x0et term got into the final solution:
You forgot the constant in the solution to the homogeneous equation:
XH = Aet
Therefore the general solution to the non-homogeneous ODE is:
x(t) = Aet + (1/2)(sin(t)-cos(t))
To find the value for A, you should use the boundary condition x(0) = x0. (You should find that A = x0 + 1/2).
Alternatively, you could carry the constant through your original solution and solve for C using the boundary condition.
