2 Identical Objects in Thermal Contact
  • Thread starter Thread starter Master J
    Contact Thermal
When two identical objects at temperatures X and Y are placed in thermal contact, they reach a final equilibrium temperature of T = (X + Y)/2, assuming no heat loss to the environment. The proof relies on the law of conservation of energy, where the heat lost by one object equals the heat gained by the other. By expressing energy in differential form as dE = C_V dT, where C_V is the heat capacity, the relationship can be established mathematically. Integrating the resulting equations confirms the final temperature formula. This discussion highlights the straightforward nature of the proof while emphasizing its basis in fundamental thermodynamic principles.
Master J
If 2 identical objects with initial temperatures X and Y are placed together in thermal contact, then the final temperature is T= (X + Y)/2, X and Y actually being equal and excluding any heatloss to surroundings.
I understand this intuitively, but is there a precise mathematical proof? It's perhaps really simple, but the situation seems so straightforward to me I can't even think of a proof.
Science news on Phys.org
The proof is based on law of conservation of energy (the energy lost by object X must be gained by object Y) and a way of writing energy in differential form, dE=C_V dT, where E is energy, CV is heat capacity, and T is temperature.
Putting these together, we have
dE_X=C_{V,X}dT_X=-C_{V,Y}dT_Y=-dE_Y[/itex]<br /> <br /> which can be integrated to give your original expression.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
