2 parallel rays are travelling in a medium
9 replies · 4K views
zorro
2 parallel rays are traveling in a medium of refractive index 4/3. One of the rays passes through a parallel glass slab of thickness t and refractive index 3/2. What will be the path differnce between the two rays due to the glass slab?
The optical path covered by the ray inside the glass slab equals the phase difference.
So x=3/2 x t
The answer is incorrect.
Dear AbdulKadir, that is easy;
l=nx right?
for first one l=(4/3)t
for second one l'=(3/2)t
path difference is (1/6)t, don't get confused, other is not traveling at space it also in a medium
Phase difference would be the difference in optical paths. One ray goes through a medium of r index 3/2, other through 4/3. Find the optical paths and subtract.
sigmaro said:
AbdulKadir
:rolleyes:
sigmaro said:
l=nx right?
The first ray doesnot travel through the glass slab. How did you write 4/3t?
So do you mean the answer will be (1/6)t?
Sorry that answer is incorrect.
A trivial problem - We have assumed c = 1. Does the answer assume that too?
A not so trivial problem - The refractive index of glass slab wrt the surrounding medium is (3/2) / (4/3) = 9/8. So the path difference would be 9/8 * t - t = 1/8 * t. This makes more sense to me because the background medium is not air (with r index 1), but a medium with r index 4/3. Does it make sense to you?
You are correct now.
But I didnot understand one thing, why did you subtract t from 9/8*t ?
9/8 * t is the optical path through the glass slab (placed in water), t is the optical path in water. Path difference = Subtract them.
In other words, the same reason we subtracted 4/3 * t earlier.
