2018 Palu earthquake seismogram recording
  • Thread starter davenn
13 replies · 5K views · last reply
from my recorder just before it started over writing the signal …
Multi-channel seismogram plot in UTC/EST with time axis marked in 10-minute intervals over about 60 minutes, showing large amplitude traces starting around 20 minutes; footer reads Maximum Velocity 0.21418mm at 09/28 10:39:15 and Start Date 09/27/18 UTC Channel ZHI BHZ DNSO, Sydney, NSW, Australia.
There were M4.8, 4.7 and 6.1 foreshocks prior to the main M7.5 main shock
since then there have been M5.8, 5.7, 5.8, 5.4, 5.1, 5.1 aftershocks
Map of the area …
Satellite map of Sulawesi, Indonesia, with a sidebar list of recent earthquakes near Palu and colored circles marking epicenters north of the city.
Dave
  • Multi-channel seismogram plot in UTC/EST with time axis marked in 10-minute intervals over about 60 minutes, showing large amplitude traces starting around 20 minutes; footer reads Maximum Velocity 0.21418mm at 09/28 10:39:15 and Start Date 09/27/18 UTC Channel ZHI BHZ DNSO, Sydney, NSW, Australia.
  • Satellite map of Sulawesi, Indonesia, with a sidebar list of recent earthquakes near Palu and colored circles marking epicenters north of the city.
Oops, that sounds serious. You already trained me to automatically first ask: Depth? Thank you, Mr. Pavlov, Sir!
Region is Sulawesi Tengah (Central Sulawesi). Borneo or Kalimantan is west across Makassar Strait.
Looking at USGS site, all preceding and subsequent quakes are shallow (10 km), except for M 6.1 - 55km NNW of Palu, Indonesia.
StevieTNZ said:
https://www.nzherald.co.nz/world/news/article.cfm?c_id=2&objectid=12133935
Only became aware of it now... didn't see anything this morning on the online news.
that will teach you for not following me :wink: :-p
Bystander said:
Borneo?
As Astronuc said, no.
That is Borneo that you can partly see in the upper left of the map
And this event has produced a 2 metre tsunami that have caused further damage.
Dave
I read this morning that there were tsunami waves of up to 3 meters in Palu and up to 6 m in some places. Perhaps the initial waves were 2 m and subsequent runup was up to 6 m?
Death toll is at least 400.
The 7.5 mag earthquake was inland. So what is this earthquake that caused the tsunami, since it was undersea?
https://earthquake.usgs.gov/earthquakes/eventpage/us1000h3t2#executive
M 5.2 - 106km NNW of Palu, Indonesia
2018-09-28 14:26:00 UTC
Location 0.022°N 119.576°E, Depth 10.0 km
Or was the 7.5 mag earthquake large enough to cause seafloor displacement?
The 7.5 mag and related earthquakes occurred in the Palu-Koro fault zone.
http://temblor.net/earthquake-insig...gering-a-tsunami-and-likely-more-shocks-7797/
Today’s M 7.5 earthquake has changed the stresses within the crust surrounding the earthquake. The amount of this stress change is moderate, especially when compared with the amount of stress that is typically released during an earthquake.
This change in stress is called a change in “static coulomb stress” and a paper that discusses the fundamental factors controlling these stress increases is from Lin and Stein (2004). There is software available to the public from the USGS to perform these calculations. This software is called “Coulomb 3” and is available online here. An introduction to this software and the physics behind the calculations can be found in Stein (2003)
Seismic and Tsunmai Hazard Potential in Sulawesi Island, Indonesia
https://ir.lib.hiroshima-u.ac.jp/files/public/3/31339/20141016181157824412/JIDC_17-1_17.pdf
I tend to agree, specially when I watched the video(s) in the links I posted. It appeared that there was a smaller initial wave,
that can be seen washing through the street and building by the seashore and the larger second wave in the background.
It was then followed by that much larger wave that hit with a lot of force completely covering those buildings on the shoreline
and being a considerable way up that large street sign on the right side of the video which is much higher than the buildings.
It is very hard to estimate heights of waves when videoed from an angle looking down on them
I strongly doubt a 5.2 could produce a tsunami, specially one of that size. I have never seen such reported in the past.
Tho they show the location of the 7.5 as being on land, remember there is a reasonable error circle around that location
and the fault that it occurred on is offshore, so seafloor displacement is likely.
Tho the fault is noted as being primarily strike-slip, it obviously does have an oblique slip component ... see the "beachball" moment tensor solution
Focal mechanism beachball diagram with blue compressional quadrants and white dilatational quadrants, labelled P and T, with nodal plane angles (350, 67, -17) and (87, 74, -156) noted at the edges.
That solution allows for a vertical offset of the seafloor.
Excellent article …. it amazes me how fast they can produce indepth info for events.
And it was good to see the offshore fault location
(cropped to fit here)
Tectonic map of the Palu-Koro Fault in central Sulawesi, Indonesia, with a blue star marking an epicentre near the Tomini Gulf and a black box labelled Fig 6.
Dave
  • Focal mechanism beachball diagram with blue compressional quadrants and white dilatational quadrants, labelled P and T, with nodal plane angles (350, 67, -17) and (87, 74, -156) noted at the edges.
  • Tectonic map of the Palu-Koro Fault in central Sulawesi, Indonesia, with a blue star marking an epicentre near the Tomini Gulf and a black box labelled Fig 6.
OK with a bit of searching, I have discovered where that video of the tsunami was taken from. It was from right at the head of that long narrow bay.
This leads to the possibility of wave amplification as it travels up the bay.
some severely reduced in size pic's from road level view.
1) aerial view of the immediate area
Aerial satellite view of a coastal area with a bay, a road running along the shoreline, a mosque and a multi-level car park. Yellow pin labelled 0.883346 119.843607 and text labels mark the mosque and the car park level the video was filmed from.
2) the carpark spiral ramp from where the video was done . The Mosque can be seen in behind the ramp. It was severely damaged in the quake shaking.
To the left side of the image is a red mast/pole, just past the street lamp pole ( the unfinished mast is where there is now a large black sign with red writing
on it ( obviously not finished when Google went through here with their street cameras)
The videographer was standing with the other people at that narrower ( in height) level, level with the word "SIMPLY"
Street-level Google Street View photo of a wide road with a yellow centre line, a green-and-white circular multi-storey car park building with a tall banner reading "SIMPLY AUTHENTIC.ID", and a white car parked beside it.
3) looking further to the left ( west)
Google Earth street view of a roadside row of open-sided wooden market stalls with pitched roofs, a blue hatchback driving on a road beside a curb, and mountains in the distant background.
4) and further again to the left ….
Google Earth street view photo of a row of open-sided thatched-roof stalls and shops along a road, with a white and red sign reading PRO on a banner, under a cloudy sky with mountains behind.
go to the location in google Earth and go into street view for a larger sized image ...
Lat -0.883346 Long 119.843607
The first thing that becomes very apparent is the changes of height from beach level to the upper road/bottom of car ramp level.
I found one spot where there was a clear view of the sea between buildings and there would appear to be approx. one to two metres
between sea level and those shoreline building floor level. The building floor level is just a little below road level
Now note from the video, the wave came right over the tops of those shoreline buildings and to around half way up that that large signage
pole (red on GE, painted white in the video). This infers a wave height of at least 4 metres and possibly more at this location.Dave
  • Aerial satellite view of a coastal area with a bay, a road running along the shoreline, a mosque and a multi-level car park. Yellow pin labelled 0.883346 119.843607 and text labels mark the mosque and the car park level the video was filmed from.
  • Street-level Google Street View photo of a wide road with a yellow centre line, a green-and-white circular multi-storey car park building with a tall banner reading "SIMPLY AUTHENTIC.ID", and a white car parked beside it.
  • Google Earth street view of a roadside row of open-sided wooden market stalls with pitched roofs, a blue hatchback driving on a road beside a curb, and mountains in the distant background.
  • Google Earth street view photo of a row of open-sided thatched-roof stalls and shops along a road, with a white and red sign reading PRO on a banner, under a cloudy sky with mountains behind.
At least 800 confirmed dead in city, sadly thrice more expected, but no signs of life in big town further along coast.
Looks bad...
Looks bad...
yeah, very bad and sad :frown:
