2nd order with exponential and constant on right side
ADGigus
Hi everybody,
How do I solve this differential equation ??:
y'' = a(Exp(-b*y)-1) ;
where a, b are constants
with the boundaries conditions :
y'(x=0)=-K1
y'(x=L)=0
without the constant term I can do
y''*y' = y' a Exp(-b y)
then integrate it
\ {1/2} (y')^2= {a/b} ~Exp(-b y)
and so on and finaly find something in hyperbolic function Tanh()...
but With the constant term " -a " on the right side, I don't know how to start.
Thank very much for your help
Welcome to PF!
Hi ADGigus! Welcome to PF! :smile:
easy-peasy …
∫ y' (a Exp(-b y) - a)
= ∫ay'Exp(-b y) - ∫ay' :smile:
ok but my problem is in the followings...
Thank you for your very quick answer and the welcome.
Yes I agree til there it's easy but it's the following that gives me troubles.
so
starting from :
y'' = a Exp(-b y) -a
y ' y'' = y ' a Exp(-b y) -a y '
after the integration on y on both sides, I have :
1/2~(y ')^2 = -a/b~ Exp(-b y) -a y + Ky' =\sqrt{-2a (1/b ~ Exp(-b y)-y) + K}
and then I'm really stuck... :-(
Hi ADGigus! :smile:
Yes … I'm stuck too. :frown:
Are you sure it's not y'' = a(Exp(-b*y-1)) ? :smile:
it's ok
Yes I'm sure it's correct,
it's coming from the expression of a Schottky diode (current density vs Voltage)
so it's :
J = a(Exp(-bV) -1)
because you want 0 current at bias of 0 Volts...
I already try many way to solve this equations, til now I'm fully stuck
Even numerically I don't find any correct way to solve it.
May be there is some polynomial approximation to use, but I don't really find anything fine.
if we take the developpement of exponential at the first order it's easy (1+V), but it's insufficient, I lose the diode physics and it does like it's something linear, so ohmic. And It's not enough for my calculation.
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
