I 2nd Order Linear ODE w/ nonconstant coefficient
Valour549
The answer in wolfram alpha is written in a compact form using the substitution e^2x. If the left hand side of the equation is solved implicitly you should get a answer to that portion of their answer that will look similar to the equation that you started with
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
