How Many 3-Digit Numbers Are Divisible by 5?
  • Thread starter Thread starter zipup
    Permutation
zipup
1. 3-digit numbers are constructed from the digits 0,1,2,3,4,5,6,7,8,9 using each digit at most once. How many such number are divisible by 5?
2. Just simply permutation, the answer is 136.
3. 8 x 7 x 2 = 128
Firstly, 8*7*2 is not equal to 128.
My calculation is:
Firstly for numbers ending in 0,
9*8 possible ways of choosing 2 digits.
For numbers ending in 5,
8*7, since we want to exclude 0
9*8 + 8*7 = 128.
My calculation is:
9*8 + 8*7 = 128.
I think this undercounts by excluding the eight numbers 105, 205, etc. (Eight since 505 is still out.) We just want to exclude 0 from the first digit, not from the second.
The counting then becomes 9*8 + 8*8 = 136, which seems to be desired answer.
PS. Why is this filed under "Advanced Physics" instead of "Precalculus Mathematics"?
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
