When does gravitational force = electromagnetic force?
Gravity is significantly weaker than electromagnetic force at the quantum level, but it dominates at larger scales, holding the universe together. The discussion explores the scale at which gravitational and electromagnetic forces might equalize, noting that this equilibrium is influenced by the mass and charge of objects involved. In macroscopic objects, the positive and negative charges of particles cancel out, resulting in no net electromagnetic force, while gravitational forces accumulate without cancellation. A mathematical analogy illustrates that while gravity can grow large, electromagnetic forces remain limited due to charge cancellation. The conversation concludes with calculations showing that an enormous number of protons would be needed to match Earth's gravitational pull with electromagnetic force, emphasizing the scale-dependent nature of these forces.
potmobius
Yes, gravity is WAYYYYYYYYYY weaker than the electromagnetic force in the quantum world, BUT when we talk about the big picture, the universe is held together by gravity. So... in that transition from the micro to the macro, can anybody tell me at what scale, roughly, the gravitational force will equal the electromagnetic force? If that's possible... I pondered over it, and I thuoght why would it NOT be possible? You do see 2 extreme scenarios in 2 extreme frames of reference, so there must exist an equilibrium somewhere...
It depends on the charge and mass of objects you're talking about.
The reason the universe is held together by gravity is that the positive and negative charges of elementary particles cancel out in macroscopic objects. More or less, for every proton that exerts an EM force, there's an electron orbiting it to exert the opposite EM force, and the two add up to no net force. But there are no positive and negative masses, so gravitational forces always add up, without any cancellations. So when you put a lot of particles together, you get a lot of gravity but essentially no EM attraction.
A little mathematical analogy:
1+1+1+1+1+1+1+1+1+... = a huge number (like gravity)
1-1+1-1+1-1+1-1+1-1+1-... = never greater than 1 (like electromagnetism)
perfect answer! Thanks so much! So, realistically speaking, that won't happen. But, if I'm looking for a mathematical equilibrium of attractive forces between a body the mass of the earth, how many protons would you need to make a planet beside Earth to equal the attractive force of gravity by earth? (assume that the earth-sized body is electrically neutral, has no magnetic field, and no atmosphere. assume that the protons are massless)
loved your mathematical analogy, btw :wink:
Thanks :wink:
As for your question about protons... if I understand correctly, you're asking how many protons it would take to produce an electric force equivalent to Earth's gravity? That depends on what's being attracted to the protons.
Here's how you'd figure it out: the formula for gravitational force is
F_G = G \frac{Mm}{r^2}
and the one for electrostatic force is
F_E = k \frac{Qq}{r^2}
In this situation, G is the universal gravitational constant, M is the mass of the Earth, k is the electrostatic constant, and Q is the charge of the "electric Earth equivalent" (which is what you're asking for).
\begin{align*}G &amp;= 6.67\times 10^{-11} \frac{\mathrm{N}\ \mathrm{m}^2}{\mathrm{kg}^2} \\<br /> M &amp;= 5.97\times 10^{24}\ \mathrm{kg} \\<br /> k &amp;= 8.99\times 10^{9} \frac{\mathrm{N}\ \mathrm{m}^2}{\mathrm{C}^2}\end{align*}
Now, if we're saying that the electrostatic force is equivalent to gravity,
F_E = F_G
or
k \frac{Qq}{r^2} = G \frac{Mm}{r^2}
or
Q = \frac{GM}{k}\frac{m}{q}
Now, you can easily calculate \frac{GM}{k} by just multiplying/dividing those numbers I mentioned. But \frac{m}{q} depends on the particle that's being attracted to the Earth or ball of protons. For example, if it were an electron, you'd use the mass of the electron m = 9.1\times 10^{-31}\ \mathrm{kg} and its charge q = -1.6\times 10^{-19}\ \mathrm{C}, do the calculations, and find that it would take 2.5\times 10^{-7}\ \mathrm{C} of charge to attract an electron as hard as the Earth does. That's just over a trillion protons, which is practically nothing - a millionth of a speck of dust, maybe.
This is, in general, a false premise...but is accurate for atomic scales. Forces are scale dependent.
Take any particle, say an electron or photon, or a group of them in a box, and compress it...reduce it's volume. When it gets small enough, gravitational attraction collapses the object and voila a black hole forms from the extreme density.
As another example, a collapsing star greater than about 1.3 solar masses will also pull itself together and naturally form a black hole without any help from us. Whether this is a "quantum world" phenomena is another issue.
diazona: Awesome once again! That's exactly what I wanted to know! Thanks :approve::biggrin:
naty1: that was random, dude! lol! :-p
