How Do I Solve These Two Circuit Problems?
  • Thread starter Thread starter supermenscher
    Circuit
The discussion addresses two circuit problems involving resistors and batteries. For the first problem, the equivalent resistance between points A and B is calculated to be 38 ohms, leading to the conclusion that the unknown resistance R is approximately 49 ohms. The second problem involves determining the magnitudes of currents through resistors R1 (36 ohms) and R2 (10 ohms) using the principle of superposition, resulting in accurate calculations that earned the user a perfect score on their assignment.
  • Understanding of series and parallel resistor configurations
  • Knowledge of Ohm's Law
  • Familiarity with the principle of superposition in circuit analysis
  • Ability to perform calculations involving voltage and current in electrical circuits
  • Study advanced techniques for calculating equivalent resistance in complex circuits
  • Learn about Kirchhoff's laws for circuit analysis
  • Explore the use of simulation software like LTspice for circuit design
  • Investigate the impact of varying resistor values on circuit performance
Students in electrical engineering, hobbyists building circuits, and anyone looking to improve their circuit analysis skills will benefit from this discussion.
supermenscher
Can someone help me with 2 circuit problems...please!
1. The equivalent resistance between points A and B of the resistors shown below is 38 ohms. Find the value of the resistance R.
The resistor looks like this
55 Ohms
_____\/\/\/\/_____
12 Ohms | |
A | |
.____/\/\/\__ | |______. B
|____\/\/\/\/_____|
R
I have no idea what to do...please help.
2. Determine the magnitudes and directions of the currents through R1 and R2, where R1 = 36 ohms and R2 = 10 ohms. I already found the directions. they are both from right to the left, I just need the magnitudes. The Bs represent batteries, and the + next to them indicates the positive side of the battery. I am also really lost on this one can anyone help?
V1=9.0V R1
--+B--/\/\/\-------
| R2 |
|----------B+------|
V2=6.0V
I would suggest using [ code ] and [ / code ] tags:
Code:
                             55 Ohms
                      _____\/\/\/\/_____
       12 Ohms        |                 |
   A                  |                 |
   .____/\/\/\_______ |                 |______. B
                      |____\/\/\/\/_____|
                               R
                            V1=9.0V     R1
                               --+B--/\/\/\-------
                               |         R2       |
                               |----------B+------|
                                          V2=6.0V
EDIT: Well, it looks best in the editor window, slightly better (but not great) in the code tags, and unreadable without those tags.
SECOND EDIT: looks fine now
For the first question, you should know how to calculate net resistances when you have resistors in series and parallel. To find the total resistance between A and B, it is:
R_{total} = 12 \Omega + (55 \Omega || R)
38 \Omega = 12 \Omega + (\frac{1}{55 \Omega} + \frac{1}{R})^{-1}
26 \Omega = (\frac{1}{55 \Omega} + \frac{1}{R})^{-1}
(\frac{1}{26 \Omega} - \frac{1}{55 \Omega})^{-1} = R
R \approx 49.310 \Omega
R = 49 \Omega
Solve question 2 using the principle of superposition. That is, find the voltages and currents with the circuit first by replacing the top battery with a short circuit, then find the voltages and currents with the top battery, replacing the bottom with a short circuit. Add the numbers from the first calculations to the second calculations, and make sure you take direction/sign into account.
Thank you so much, I got them both right and 100 on the assignment :) :) :)
  • · Replies 18 ·
  • · Replies 19 ·
