Origins of the 360 Degree Circle Convention
The 360-degree circle convention likely originates from ancient Babylonian mathematics, which utilized a base-60 numeration system. This system influenced the division of time and angles, leading to 60 seconds in a minute and 60 minutes in a degree. The approximation of 365 days for Earth's revolution around the sun also contributed to the adoption of 360 degrees. The choice of 360 degrees may reflect a combination of these numerical systems and astronomical observations. Overall, the convention is deeply rooted in Babylonian practices and their mathematical framework.
jobyts
Where did the 360 degree for a circle convention come from? By any chance, is it from the ~360 days for the Earth to revolve around the sun?
Mathematics news on Phys.org
Could be. 360 deg. seems to come from the ancient Babylonians.
The Babylonians used a numeration system based on multiples of 60. That, together with the fact that 365 is close to 360 influenced the choice.
they worked in base 60 didn't they?
*got there too late*
Yes. That's how we get 60 sec. = 1 min. and 60 min. = 1 hr. for time, and also 60 sec. = 1 min. and 60 min = 1 deg. for angle.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
