MATLAB Calculating 3D Least Squares Fit with SVD in MATLAB
The discussion focuses on calculating the Least Squares Fit Line for a 3D dataset using Singular Value Decomposition (SVD) in MATLAB. SVD is explained as a method to factor a matrix into three components, which aids in solving least squares problems efficiently without extensive matrix multiplications. The user is working with a specific set of points and seeks clarification on the meaning of direction cosines and the process of selecting the smallest singular value and its corresponding vector. Additionally, alternatives to SVD, such as QR factorization, Gauss Elimination, and LU decomposition, are mentioned for solving least squares problems. The thread emphasizes the importance of understanding these matrix methods for effective data fitting in 3D space.
mjdiaz89
Hello,
I am trying to write an algorithm to calculate the Least Squares Fit Line of a 3D data set. After doing some research and using Google, I came across this document, http://www.udel.edu/HNES/HESC427/Sphere%20Fitting/LeastSquares.pdf (section 2 in page 8) that explains the algorithm for
It uses something from Linear Algebra I have never seen called Singular Value Decomposition (SVD) to find the direction cosines of the line of best fit. What is SVD? What is a direction cosine? The literal angle between the x,y,z axes and the line?
For simplicity's sake, I'm starting with the points (0.5, 1, 2) ; (1, 2, 6) ; (2, 4, 7). So the A matrix, as denoted by the document is (skipping the mean and subtractions)
A = \left \begin{array} {ccc} <br /> [-1.6667 &amp; -1.1667 &amp; -2.8333 \\<br /> -2.0000 &amp; -1.0000 &amp; 3.0000 \\<br /> -2.3333 &amp; -0.3333 &amp; 2.6667 \end{array} \right]
and the SVD of A is
SVD(A) = \left \begin{array} {ccc} <br /> [6.1816 \\<br /> 0.7884 \\<br /> 0.0000 \end{array} \right]
but the document says "This matrix A is solved by singular value decomposition. The smallest singular value
of A is selected from the matrix and the corresponding singular vector is chosen which
the direction cosines (a, b, c)" What does that mean?
Any help will greatly be appreciated. Note: I am working in MATLAB R2009a
Thank you in advance!
The document in the link explains how to use SVD. It's just a method to factor a matrix A into a product of three matrices A = USVT where U and V are orthogonal matrices and S is diagonal. It is useful in solving the least squares normal equation ATAx= ATb for x by avoiding the matrix multiplications of ATA and ATb. The steps are listed in the document. In the end, you can solve for x as follows:
x = VS-1UTb
QR is another matrix factorization that also allows least squares problems to be readily solved. In this case, A = QR, where Q is orthogonal and R is upper triangular. The solution to the least squares problem then becomes:
Rx = QTb
which is easy to solve for x because R is triangular. The following link explains the use of both SVD and QR for solving least squares problems:
http://en.wikipedia.org/wiki/Linear_least_squares
Besides SVD and QR, you can also use standard Gauss Elimination, LU decomposition (based on Gauss Elimination), or Cholesky decomposition (because ATA is symmetric).
http://en.wikipedia.org/wiki/Matrix_decomposition
Hello,
in the paper referenced below, the exact analytical solution is developed in two cases :
- Least Squares Fitting to a straight line in 3d (orthognal distances between each point and the line)
- Least Squares Fitting to a plane in 3d (orthogonal distances between each point and the plane)
The method isn't iterative ( definitive result is directly achieved in only one run of computation)
A compendium of formulas is provided for practical use page 7 (case of fitting to a straight line) and page 18 (case of fitting to a plane)
Numerical examples are provided for tests.
Link to the document :
http://www.scribd.com/people/documents/10794575-jjacquelin
Then select "Regression & trajectoires 3d."
