4 spaceships are pulling a membrane through an asteroid belt
  • Context: Undergrad
  • Thread starter Thread starter eaglechief
    Asteroid Belt Membrane
The discussion centers around a hypothetical scenario involving four spaceships pulling an elastic rubber membrane through an asteroid belt. Participants explore the dynamics of rocks interacting with the membrane, the implications of the membrane's properties, and the potential analogy to gravitational effects.
  • Some participants propose that as the membrane passes through the asteroid belt, rocks will come into contact with it and be accelerated to match the membrane's speed.
  • Others argue that the rocks will not simply match the membrane's speed but may accelerate beyond it due to their inertia.
  • There is discussion about how the mass of the rocks affects the curvature of the membrane, with larger rocks causing more significant dents.
  • Some participants question the concept of "clinging" rocks and suggest that the interaction is more transient, with rocks bouncing off rather than accumulating.
  • One participant raises the idea of using a moving inertial system to simulate gravitational effects, prompting questions about what specific effects are being referenced.
  • There is a critique of the rubber sheet analogy for gravity, with some suggesting it fails to account for time curvature and other complexities of general relativity.
  • Another participant reflects on the potential for a constant linear velocity setup to demonstrate gravitational effects, drawing parallels to circular motion scenarios.
Participants express differing views on the behavior of rocks in relation to the membrane, particularly regarding their acceleration and interaction. There is no consensus on whether the rocks will collect or bounce off the membrane, and the discussion remains unresolved regarding the effectiveness of the rubber sheet analogy in explaining gravitational effects.
Limitations include the lack of clarity on the membrane's properties, such as its energy absorption capabilities and how these might affect the interaction with the rocks. Additionally, the assumptions regarding the rocks' behavior and the analogy to gravitational effects are not fully explored.
eaglechief
TL;DR
I'd like to understand if a constant moving inertial system could simulate gravitational effects
Given 4 spaceships are pulling an elastic rubber membrane with constant speed and slow velocity into an asteroid belt.
- In that way, that they all start in empty space and have a constant low speed of say 50km/h as they reach the belt.
- The four edges of the membrane are tied to one of the four spaceships.
- the spaceships do not slow down and pass the asteroid belt with constant speed
- the rubber membrane is made that way, that on Earth a rock weighting 10kg is curving the membrane visibly
- the asteroid belt constains different kind of rocks from 10kg to 100kg in random distribution
- the rocks of the belt have no speed and are resting with v = 0 in the belt
will the following happen or not ?
(a) as the brane passes the the belt, single rocks will have contact to the brane and are beeing accelerated in the direction the spaceships are heading until they move with the same velocity of 50 km/h as the brane and the 4 spaceships (Yes/No)
(b) due to the inertia of the rocks the rocks will curve the brane and different dents occur depending on the mass of the different rocks (Yes/No)
(c) 100kg rocks will cause bigger dents with larger radius. Smaller rocks which are klinging to the membrane in the very neighbourhood will begin to accelerate towards the bigger dents (Yes/No)
(d) "bulk dents" appear, where several rocks have been collected by the heaviest rocks (Yes/No)
(e) distributed along the membrane will occur more and more bulk dents which are curving the membrane locally in a strong way and are collecting further single rocks as well as other smaller bulk dents (Yes/No)
Thanks in advance
Carlo
You speak in passing about rocks "klinging to the membrane". But you have not spoken about the energy absorbing or dissipating capabilities of the membrane directly at all. [We also do not know its areal density or lateral tension. So the speed of transverse and compressional rubber sheet waves is unknown]
Why do you expect the rocks to end up moving at 50 km/h rather than 100 km/h?
If this is supposed to be related to relativity, it sounds like you are trying to motivate a rubber sheet model. But it's best to ignore the rubber sheet model and actually learn general relativity instead.
Can't be. You're describing hitting a bunch of asteroids with a giant badminton racquet. The asteroids pressing into the rubber sheet are not going to stay there, but instead will be accelerated with the motion of the setup and bounce ahead of the motion of the sheet. They will for a finite time press into the sheet, yes.
No. They'll continue to accelerate to faster than the sheet.
And also depending on how far from the supported edges the force is applied. A rock near a ship attachment point will cause a smaller dent and be in contact with the brane for less time than a similar mass rock near the center. The rock near the ship will be correspondingly defected to the side, not straight forward.
Even the small rocks deflect the entire sheet, so there's not a radius to it, just like there's not a radius to the reach of gravity, which seems to be the analogy you're suggesting. Big rocks deflect it more, all else being equal, yes.
Depending on when they hit, but yes. The dents are temporary.
You made no mention of clinging except for this. If the sheet has glue, the dents will osculate both ways and no 'collection' or other lateral movement will take place. It then becomes a giant vibrating fly strip.
There's little chance that they'll hit each other, so no.
No collection takes place. Everything bounces away after brief contact, so no.
What "gravitational effects" do you think your setup is trying to simulate?
This reminds me of the Flat Earth theory that we are accelerating "upwards" at 7.2m/s which is why we "experience" gravity...
Thanks for your replies. I learned from your answers that the setup will not "collect" any rocks from the meteorite belt but causes some kind of space-tennis :smile:
I tried to understand if the "rubber-membrane" analogy explaining gravity by showing stars and planets curving the membrane could be amended in that way, that (a) the membrane itself is moving and (b) not accelerated but with a constant speed, instead.
In addition to that, i was thinking about the experimental set-up, where circular motion with constant speed is causing gravitational effects, as well, and if that could be transformed in a set-up where a constant linear velocity is used ...
You seem to be trying for a "rubber sheet" model of gravity. It's an absolutely terrible model, because it only talks about the spatial curvature and completely misses the "time curvature" (scare quotes, because that's not really a clear concept, but it'll do for this point). All gravitational effects in every day life can be traced to that bit of curvature that is left out of the rubber sheet model - spatial curvature is a very tiny correction.
This post has a much better diagram. Also this post, and also this video. All thanks to @A.T.
This won't work because the whole point of the rubber sheet analogy is that it only shows "space" at an instant of time, and that "space" stays the same at every instant of time. So nothing changes about "space" in this analogy; but "motion" implies that something is changing.
What kind of "gravitational effects" due to circular motion are you talking about? If you mean things like seeing "centrifugal force" if you are inside a spinning space station, say, then the linear analogue is being in a linearly accelerating rocket and watching a dropped rock "fall" towards the bottom of the rocket due to a "pseudo-gravitational force". In both cases the source of the "force" is the fact that your motion has nonzero proper acceleration: you feel a force (in the spinning space station, a force pushing you against the outside wall; in the linearly accelerating rocket, a force pushing you upward as you "stand" on the bottom of the rocket). But if you are moving with constant linear velocity, you feel zero proper acceleration, and you will observe no such "forces".
