Does resistance go up or down with an increase in temperature?
Resistance behavior in materials varies with temperature, influenced by their specific properties. Metals typically exhibit a positive temperature coefficient, meaning their resistance increases with temperature, while semiconductors show a negative temperature coefficient, resulting in decreased resistance as temperature rises. Low temperature coefficient materials, such as Manganin, maintain approximately constant resistance across temperature changes, making them ideal for precision resistors. Understanding these principles is crucial for applications in electronics and materials science.
  • Understanding of electrical resistance and conductance
  • Familiarity with temperature coefficients in materials
  • Knowledge of semiconductor and metal properties
  • Basic principles of resistivity and its dependence on temperature
  • Research the properties of Manganin and its applications in resistors
  • Learn about positive and negative temperature coefficients in materials
  • Explore the behavior of semiconductors under varying temperature conditions
  • Investigate low temperature coefficient materials and their industrial uses
Students, electrical engineers, materials scientists, and anyone interested in the thermal properties of materials and their applications in electronics.
Femme_physics
I had 2 people telling me 2 different things...so I don't know the real answer. Does resistance go up or down with an increase in temperature?
Yes it can go up or down. It depends on the material.
Can it stay constant, too?
Yes, at least approximately constant. That would be called a low temperature coefficient material.
Materials in which resistance increases with temperature are referred to as having a positive temperature coefficient. Most metals are in this category.
Materials in which resistance decreases with temperature are referred to as having a negative temperature coefficient. Most semiconductors are in this category.
In most metals, the resistance goes up with temperature. In semiconductors, the resistance actually decreases as temperature rises. I think resistivity will always change depending on temperature. But for some materials the change might be relatively small.
Actually Manganin is an alloy, which has a coefficient of resistivity of .000002. This is used for resistors because its change in resistivity due to temperature is very close to 0.
The problem with wiki is that it tends to provide more than the needed information which often confuses the reader (i.e. me)... those answers here helped me though..thanks :)
  • · Replies 23 ·
