Can Wind and Water Sounds Be Distinguished in Nature?
  • Thread starter Thread starter anorlunda
    Water Wind
The discussion centers on the difficulty of distinguishing between the sounds of wind and running water during a camping trip. The poster notes that various environmental conditions, such as moderate winds in different terrains and the presence of streams and waterfalls, produce sounds that are hard to differentiate. They mention a personal limitation in hearing above 3K hertz, which may affect their perception. The conversation references previous discussions about wind noise and suggests that the mechanisms of sound production and transmission for wind and water may share similarities. The poster seeks confirmation on whether their experiences reflect a broader phenomenon regarding sound spectra.
anorlunda
Staff Emeritus
Insights Author
I just returned from a tenting trip. In a tent, one hears the sounds of night more plainly. I was struck by the fact that, try as I might, I can not distinguish the sounds of wind from those of running water. Specifically,
  1. Moderate winds (15-30 kt) in the forest.
  2. Moderate winds (15-30 kt) on a bare surface in the desert.
  3. Moderate winds (15-30 kt) in a rock canyon.
  4. A mountain stream with white water rapids. Water speed ~25 kt.
  5. A nearby waterfall.
  6. A river, much larger and deeper than the mountain stream but swift (~8 kt).
I should confess that my ears hear nothing above 3K hertz. Nevertheless, none of those noises sound to me similar to electronically generated white noise.
I am also a sailor, so I can report that at sea, the sounds of wind are always confused with the sounds of waves, so that I can't ask the same questions in that case.
I found a previous thread about wind noise on this forum. The answers provided had to do with vorticies. But I expect the mechanisms of noise production and transmission to be very different for wind and running water. I suspect that at least some of the water sounds are transmitted through the ground.
Are my perceptions correct; are the spectra of these diverse noise sources really so similar?
If yes, is it just coincidence or are there similarities in the noise production and transmission mechanisms?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
