Computable Normal Numbers: Is There a Known Answer?
The discussion centers on the existence of computable normal numbers, with a focus on the Champernowne constant, which is known to be normal in base 10. A referenced paper claims to demonstrate the existence of a computable absolutely normal number, which is normal in all integer bases. The term "computable" refers to numbers whose digits can be generated by a Turing machine. There is curiosity about whether a polynomial-time computable normal number exists and its implications for mathematical conjectures. Overall, the conversation highlights the complexity and significance of normal numbers in mathematics.
Dragonfall
Wikipedia is not very clear on this. Is there a known computable normal number?
I found this paper:
http://www.glyc.dc.uba.ar/santiago/papers/absnor.pdf
But I'm not sure if it's been peer reviewed.
Mathematics news on Phys.org
What do you mean with "computable"?
Anyway, consider the Campernowne constant. It is just
0.123456789101112131415161718192021222324...
This is known to be normal (one of the very few explicit numbers known to be normal, although it is also known that "most" numbers are normal). And it will probably also satisfy your criterium of computability.
http://en.wikipedia.org/wiki/Champernowne_constant
Now, your paper (which certainly is peer-reviewed and correct!) shows the existence not only of a computable normal number, but of an computable absolutely normal number. This means that it is normal in any integer base ##\geq 2##. Champernowne's constant is only known to be normal in base ##10##. I don't think any other examples of absolutely normal computable numbers are known, but I'm not an expert.
Yes, I meant "absolutely normal". Computable means digits are enumerable by a Turing machine or uniform family of circuits. That paper presents a super-exponential-time algorithm for computing Sierpinski's construction.
Is there a known polynomial-time computable normal number?
How many conjectures will the existence of such a number ruin?
Very few of significance, I expect. (In fact, it's conjectured that most of the computable mathematical constants we're familiar with pi or Euler's number are absolutely normal.)
Good point.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
