bobie
- 2
We know that z redshift (+1) ir the ratio between the observed and emitted wavelength.
Could you tell me, in practice, how you can you find z for a star? or can you give me a link where a particular case is explained in detail?
Any object (star, (proto-)galaxy,quasar) emits EMR in a wide range of frequencies.Take a quasar:
The first problem is to isolate a single frequency, I suppose. But when you've done that,
- how do you determine what was the original emitted frequency? in the quoted example , if the observed frequency is 2*1014 we must ascertain that the emitted frequency was 6.152*1014, then: 0.00015/0.00004877= 3.076, -1 → z = 2.076. Is this correct?
- when you determine the emitted frequency you find z, then, what is the formula to derive from 2.076 the distance (in time) 10.5 Gy or (in space) 10.5 Gly?
Thanks for your help
Quasars are extremely luminous and were first identified as being high redshift sources of electromagnetic energy, including radio waves and visible light, that appeared to be similar to stars, rather than extended sources similar to galaxies. Their spectra contain very broad emission lines, unlike any known from stars, hence the name "quasi-stellar". Their luminosity can be 100 times greater than the Milky Way...
LBQS 1429-008 ... quasar has a red shift of z = 2.076, which is equivalent to 10.5 billion light years
