Understanding Eigenspaces: Solving Exam Questions
  • Thread starter Thread starter klingenberg
The discussion clarifies the concept of eigenspaces in relation to eigenvalues and eigenvectors. It emphasizes that the order of eigenvalues does not affect the eigenspace they span. The notation used by the original poster was deemed confusing, as it mixed terms and concepts. It is confirmed that the eigenspaces associated with vectors <1, -1> and <-1, 1> are indeed the same, as they lie along the same line in R2. Clear notation is essential for understanding these mathematical concepts.
klingenberg
I know this might be trivial, but when practicing for exam, I usually write the "inverse" values of the cheat sheet, and want to make sure I'm not making a mistake.
Is the eigenspace 1,-1 the same as -1,1?
Mathematics news on Phys.org
I think your difficulty is your "notation" which is so terse as to be confusing. 'The eigenspace 1, -1' makes no sense to me. If you mean "the subspace spanned by eigenvectors of linear operator A corresponding to eigenvalues 1 and -1" then it should be clear that the order in which you mention the eigenvalues is irrelevant.
(I started to write "the subspace of all eigenvectors of linear operator A corresponding to eigenvalues 1 and -1" but you understand that that set is NOT a subspace, right?)
To put it a bit differently, an eigenspace is a (vector ) subspace , and {1,-1} is not, at least not in any way I' familiar with. Did you mean the eigenspaces associated to each of these eigenvectors?
If your notation 1, -1 is intended to mean the vector <1, -1> in R2, then yes, the space spanned by the eigenvector <1, -1> is the same as that spanned by the vector <-1, 1>. Both vectors lie along the line y = -x but point in opposite directions.
Perfect, thanks. Sorry about the confusing notation.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
