Choosing the Right Power Supply for Your M-Audio Keystation 61es MIDI Keyboard
The M-Audio Keystation 61es MIDI keyboard requires a 9V DC power adapter with a current rating of 250-300mA, but the manufacturer recommends a 9V 500mA supply. Users are confused about the appropriate power supply, especially when considering alternatives like a 9V 800mA or 9V 300mA adapter. The 300mA adapter is deemed safe as it meets the keyboard's requirements, provided the polarity is correct. Input specifications are also important, particularly regarding mains voltage compatibility.
rspaulding
I need a power supply for my M-Audio Keystation 61es MIDI keyboard, and I think I might have one that will work for it.
The user manual for the keyboard says this:
"You can also use a power adapter (not included) with the following specification: 9V DC output, 250 - 300mA, center positive"
But then their website is selling a 9v 500mA as the proper replacement:
http://www.m-audio.com/products/en_us/PowerSupply9VDC500mA.html
And every other online retailer sells a 500mA supply as the replacement:
http://accessories.musiciansfriend....upply?sku=500930&CJAID=10381297&CJPID=2179950
A little bit confusing, but I have two laying around that might work, one is 9V 800mA and the other is 9V 300mA. Do you think either of these will be safe? If so, which one?
Also, do the "input" specs on the supply matter much?
The user manual for the keyboard says this:But then their website is selling a 9v 500mA as the proper replacement:
Welcome to Physics Forums.
Looks like your keyboard requires up to 300 ma @ 9 volts. The output of these types of adapters indicate the maximum amount of current they can supply. So the 300mA one you have should work. What you want to make sure of is that the center connector terminal is the positive one (proper polarity).
Yes the "input" specs matter. If you're in the US, mains voltages are 115vac. Other counties mains may be 230vac.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
