hokhani
- 561
- 18
Why a magnet bar would become aligned with the external magnetic field while a magnetic moment would precess around the external magnetic field?
I want to raise the spin magnetic moment.Vanadium 50 said:How is this quantum mechanics?
Please see http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/larmor.htmlVanadium 50 said:where are you getting this from?
As you said, my main question is "why a classical magnet behaves differently than a quantum mechanical one"; If a classical magnetic moment were in an external magnetic field, it becomes aligned with the magnetic field or would have a precession around the magnetic field (I also don't know the difference between these two as raised in my first post here) while the spin state would not change in an external magnetic field. For example, the state ##|S_x+,t_0>=1/\sqrt(2)|S_z+>+1/\sqrt(2)|S_z->## in the magnetic field ##\vec B=B_0 \hat z## changes as ##|S_x+; t>=exp(-i\alpha t) |S_x+,t_0>## which means that the spin state hasn't changed in the magnetic field.Vanadium 50 said:Your question is still extremely vague. Are you asking why a classical magnet behaves differently than a quantum mechanical one? Or are you asking why precession exists in the first place?
hokhani said:why a classical magnet behaves differently than a quantum mechanical one
I believe the source of confusion of the OP is the angular momentum involved. Precession requires external torque and "large" angular momentum. For a macroscopic bar magnet the onboard angular momentum causing the magnetization is negligible. Not so for a proton.vanhees71 said:I still don't get the question. A classical magnetic moment doesn't behave so differently from the quantum one (at least in the sense of Ehrenfest's theorem).
